BMW 3-Series (E90 E92) Forum
over boost and limp mode?
| 03-17-2013, 03:10 PM | #1 |
Rep 1,137
I've been having an issue with my car going into limp mode when i go WOT. pulls like a frieght train then "bing" service engine soon light! I'm running procede and mods in sig. Any advice or suggestion are welcome.
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
| 03-24-2013, 02:19 PM | #3 |
![]() 28
Rep 82
did you ever figure out your problem? i turned on my JB4 to have a little fun and when i laid it down, same thing...pulled super hard and then the SES came on. I pulled off to the side of the ride, turned off the JB4...waited a little bit and restarted my car and it was back to running normal again, no limp...
haven't had time to look under the hood but the engine has been running fine since...still makes me wonder what the hell happened? |
| 03-24-2013, 03:38 PM | #4 |
![]() ![]() ![]() ![]() 41
Rep 622
It doesnt necessarily mean its a vacuum leak??? When I had a vacuum leak I had no codes but would only get 0psi of boost with the JB4 G5 ISO on map 5 (autotune map) as well as map 0 (stock like mode). Long story short I replaced all my vacuum lines with silicone hoses just because there alot more durable and since I was already going to go ahead and replace them I thought why not get something that will most probably eliminate any leak in the future. If you are throwing a check engine light followed by limp mode it could be an injector, coil pack, spark plugs ect...
Also are you using E85 at all? If you are you probably need to increase your open loop mapping on your rev 2.5...I dont know if the Procede has that or maybe its called something else but that could be another issue as well. If you max it out you need to decrease your E85 content or upgrade to the Walboro LPFP. But if this just started happening and you didnt have any problems before i bet money its a spark plug/coil pack or injectors. hook your lap top up and read the codes since it should be a hard code and it should be stored on your Procede even if you turn the car off and turn it back on it should still be stored. I would start by reading the code then we could probably better assist you and your issue.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
| 03-27-2013, 01:41 PM | #5 |
![]() 28
Rep 82
With what we were doing at the time...could this be also a HPFP issue too? Just bought the USB cable so when I get time I'll plug in and read the code, but I just bite my fingernails thinking I will have to get the HPFP replaced again...even when I got it replaced just a couple thousand miles ago
| 03-27-2013, 02:33 PM | #6 | |
![]() 32
Rep 259
Drives: 2009 335i
I have had this issue a few times now i havent put E85 in my tank in about 2-4 fillups. and I have had the Engine Malf light come up, wait 2-5 mins and it is gone. When i use E85 I only do 30% ratio and run JB4 G5 Board ISO Map 5 and it runs likea champ. and no issues. I know i dont have a vacume leak i checked, a few weeks ago and my def wastegate position is 80 Suggestion is change plugs? increase fuel open loop to 2.5 what should it be normally running 15-30% E85 or is that dependednt on the car anything else i should look at thanks
09 335i Sport --MHD (Tune by Wedge )--Inlet System by Trueform Technologies --Tial BOV--Macht Schnell Catless Downpipes--AMS FMIC--Walbro 455 LPFP--HPF Gen2 Exhaust--SPEC Stage 3+ clutch / billet steel flywheel--
| 04-04-2013, 12:24 PM | #7 |
Rep 5,382
same thing happening to me with and without my cobb tune.
| 04-14-2013, 04:25 PM | #8 |
Rep 1,137
I did a pull today and it seems to be a misfire on #5. Only seems to do it at high boost meth map. I'm fine to 18 psi but when my meth map switches to 20psi at redline it misfires.
| 05-29-2013, 12:25 PM | #9 |
![]() 7
Rep 73
I have the same issue with my n54, I bought the car used at 140Km and it started happening everytime I went WOT, it doesn't happen on low RPM but when I go past 5 on third gear perhaps the orange engine light comes on and car goes into limp mode, and I can stop the car and turn it off and turn it back on right away and everything goes back to normal. It really pisses me off. will be taking the car in to have it checked out, Ill post back when I get it figured out.
| 12-03-2013, 05:11 PM | #11 |
Rep 1,137
I changed to new plugs and it went away.
| 03-07-2014, 01:26 AM | #12 | |
![]() ![]() 22
Rep 317
| 03-08-2014, 08:59 AM | #13 |
![]() 7
Rep 73
No, have not yet figured out the issue, have taken the car to 2 different bmw Indy shops neither helped, both said at the end take it to bmw to diagnose the issue.
We found a little leak on the pipe which goes from the turbo to the intercooler which seemed to have some oily spots around the bend just before the intercooler, I told him to change it, but he refused, assuming that this isn't the major problem. My third party warranty only pays for $70 of the diagnose, so I'm afraid to take it to bmw and it takes them few hours to figure out the issue and be stock with a $500+ bill just for diagnoses. So I have left it as is for now. I will soon be ordering some new spark plugs as I have not changed them since I bought the car 20,000 km before. |
| 06-19-2020, 02:58 PM | #14 | |
![]() 18
Rep 119
30fe and 3100 codes moste likely overboosting Started after I installed downpipes and upped the tune |
| 06-19-2020, 03:22 PM | #15 | |
![]() ![]() ![]() ![]() 736
Rep 946
Bumping old threads like this isnt going to solve your problem. Post logs and any codes in a new thread. Did you test your boost solenoids?
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
Sgop335745.00 |
| 07-11-2022, 06:40 AM | #16 |
Rep 6
anybody figure this out
Its a very old thread but has anyone ever figured out the issue?
Mine is a N55 and I think I have narrowed it down to either the boost solenoid, wastegate, or a leak (I was getting under boost and Limp on WOT, and after changing the JB4 settings I am now getting over boost and WOT.) |
| Bookmarks |
