TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Problems after VCG change
      04-15-2026, 01:22 AM   #1
Nicholg2286
Drives: 07 E90 / 09 E92 / 01 E46
2008 328i N51
Buddy of mine has this 2008 328i that ran fine but had a leaking VCG. He changed the gasket, did the valvetronic relearn and had no problems reassembling everything.
Ran fine upon completion, but over a couple of weeks and maybe 100 miles it began to have a rough idle which progressed into the higher rpm ranges. Progressed further into stalling then even further to the point that it now won’t start.
He has asked me to help diagnose. He says that it does not show any codes on his OBD scanner. He doesn’t have ISTA - which I plan to scan with thanks to my laptop.
I also plan on smoke testing it as my gut is telling me there is a vacuum leak, but I have nothing other than my gut to tell me that.
What else would you check? I was planning on checking fuel rail pressure to establish good fuel pump. What would correct rail pressure be?
I’m in need of ideas so anything you can offer would be greatly appreciated!!
      04-15-2026, 10:31 AM   #2
bmwbob89
Drives: 07 328XI 04 325XI 740 88 M5
I always say, look whe the last idiot was even if it's you!
New problem usually means you did something wrong.
Nothing personal we all make mistakes.
Tags
2008 328i, help a noob, valve cover gasket, won’t run
