BMW 3-Series (E90 E92) Forum
Help combox retrofit
| 04-13-2026, 09:59 PM | #1 |
Rep 10
I have a 2011 328I with Bluetooth calling but not audio. I got my hands on a Combox from a 2011 328I with BT audio. I was wondering how hard it would be to retrofit and if anyone who has done it could point me in the right direction?
| 04-15-2026, 01:29 AM | #2 |
![]() 893
Rep 3,786
check what module you already have in trunk and also check options list by VIN
because you may already have combox but bt audio options is not enabled because combox was installed on e90 and 91 from oct 2010 and on e92 e93 from apr 2010 so in US you have confusion, when you tell 2011 bmw this usually mean the car is made in 2010 but how is that in Canada ? because in Europe car made in 2010 is 2010 car, not 2011
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
E91 328i0.00 |
| 04-15-2026, 08:37 AM | #3 |
![]() 4730
Rep 2,746
- combox need to be a bn2000 with the black connector (doupt in 2011 is was an option in a e9x series ? ) .
- repin the 2 main connectors - NCS expert to add the option. I've used this DIY : https://www.e90post.com/forums/showthread.php?t=1891694 Was easier than I thought, I should have done this way before, since I run a carplay box that was using AUX, now it use BT, so the sound is better. Only issue I have : the skip track button on the steering wheel dont always register the right way. |
E91 328i0.00 |
| 04-15-2026, 11:37 AM | #4 |
Rep 10
so I checked and I have MLUF 2 high just the single box and below are my options. From what i've read, it should be plug and play I would just need help coding it if anyone would be able to guide me.
Attachment 3942616 VIN A541463 Prod. Date 2010-04-28 S609 Navigation system Professional S620 Voice control S639 Preparation f mobile phone cpl. USA/CDN S645 BMW US Radio S653 High Definition Radio S655 Satellite tuner S688 Harman/Kardon surround sound system S697 Area-Code 1 for DVD S6AA BMW TeleServices S6AB Control, Teleservices S6FL USB/audio interface |
| 04-15-2026, 03:39 PM | #6 |
![]() ![]() ![]() ![]() 498
Rep 760
Google e90 combox retrofit. You will find many guides online. I'll put a link below that i used when doing this to an E61. It's not plug and play. You need to change the connector and repin a few wires.
https://www.e90post.com/forums/showt...hlight=faxdata Last edited by NZE90; 04-15-2026 at 03:46 PM.. |
| Bookmarks |
