TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Vanos codes on my N54- P0012, 2a82
      04-12-2026, 06:40 AM   #1
franekkopec
Drives: Bmw 335is
Angry Vanos codes on my N54- P0012, 2a82
Hi,
I have been experiencing persistent VANOS issues with my N54 engine for some time. Although the car generally drives well, shifting from 1st to 2nd gear occasionally triggers fault codes 2A82 (Inlet VANOS) and P0012 (Inlet Camshaft Position Timing - Over-Retarded).
The idle is mostly stable, though I occasionally experience 'idle wobble' where the RPMs drop by about 100 and returns to normal. To resolve this, I have already replaced the following:
  • VANOS Solenoids
  • Camshaft Position Sensor
  • Oil and Filter
  • Oil Filter Cap (Non-OEM)
Also when it comes to an Oil Filter Cap I changed it 500 miles later than the Oil and Filter.
Any help would be really appreciated.
      04-12-2026, 08:56 AM   #2
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2007 BMW 328i E91  [10.00]
2009 BMW 328i E91  [7.56]
2006 BMW 330i  [8.17]
2007 BMW 328i  [8.83]
2013 BMW X5 35i  [8.43]
2011 BMW 528i  [9.07]
Swap the solenoids and see if the code migrates to the exhaust side. Pretty good chance it's the solenoid. If it persists on inlet side, swap the sensors in the same way. If it still stays on the inlet side, I'm out of ideas.
      04-14-2026, 12:24 PM   #3
lookalikehuuh
Drives: 2006 330i, 2007 335i
It says you replaced the VANOS solenoids, etc... where did you source the parts and what brands are they?
GoRomeo1799.00
      04-14-2026, 12:35 PM   #4
lordnikon
lordnikon's Avatar
842
Drives: Break My Wallet
2A82 fault code may trigger if your oil filter basket is missing or broken.
      04-14-2026, 12:44 PM   #5
lordnikon
lordnikon's Avatar
842
In my experience, the car is picky with VANOS solenoids. I installed genuine ones and no more issues.
      04-14-2026, 06:59 PM   #6
StradaRedlands
I put on some used low mileage BMW ones from a wrecker.
      04-15-2026, 11:31 AM   #7
lookalikehuuh
Yeah I was going to recommend OP had purchased genine BMW ones, or at least used some known good used units... since it appears there are 0 other companies that can make good VANOS solenoids nowadays.
      04-15-2026, 06:56 PM   #8
StradaRedlands
Yep, and even original BMW parts aren't holding up like the original. At least BMW does a good job keeping maintenance items for out of production cars in stock! But anecdotally, the quality of those is slipping as well.
      04-15-2026, 08:49 PM   #9
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [6.33]
2006 330i  [6.75]
Dude really??
      04-15-2026, 11:34 PM   #10
StradaRedlands
Originally Posted by GoRomeo View Post
Dude really??
Yep. Got 'em from a car that had 42k on them (Jackie Robinson Day!). Got the solenoids, cam sensors, and check valves. Heck, I stripped that car clean:
Blower & Resistor
Fuel Injectors (6)
Windshield washer pump
Heated Sport Seats
3SIM with DISAs
Starter
Ground Strap
MAF Sensor
Crank Position Sensor
Fuel vapor valve
Fuel vaport tank/pump
N51 Radiator & Sensor
Radiator Fan
Upper radiator hose
Lower radiator hose
Heater hoses (U & L)
VANOS solenoids (2)
VANOS sensors (2)
VANOS Check Valves (2)
GoRomeo1799.00
lordnikon841.50
      04-16-2026, 12:27 AM   #11
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Blower & Resistor
Fuel Injectors (6)
Heated Sport Seats
3SIM with DISAs
Starter
Ground Strap
MAF Sensor
Fuel vapor valve
Radiator Fan
Upper radiator hose
Lower radiator hose
VANOS solenoids (2)
VANOS sensors (2)
I wouldn’t get used solenoids for mine but I guess it can work out for you.
      04-16-2026, 12:48 AM   #12
StradaRedlands
Yep, they work like a charm! Like I mentioned above... I'd rather have used BMW ones than new OE ones at this point.
GoRomeo1799.00
