Jacob.falkmfg
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > e91 320d cranks but doesn't start
      04-10-2026, 01:49 AM   #1
0kolokole
Drives: bmw e92 320d
Hi everyone. I have problem with my e91 and I think I'm going crazy. car cranks normally but doesn't start. it all started when car slid into a ditch when bank under it collapsed while it was parked. car wasn't on when it happened, and there was no any visible damage on it. water did enter on the right side, not much but carpets were wet. i dried the car, checked everything for water before trying to start it up. car cranks normally but doesn't turn on. i drained fuel tank and changed fuel filter just in case and still car cranks but no start. then i went to check fuel pump, car started twice and worked normally. I turned it off, tried to start it tomorrow and car doesn't want to start. i tested fuel pump and it's fine, I changed fuel pump module and fuel pump relay and it still doesn't start. I checked for codes and car gives none. I'm out of ideas, pls someone help
Last edited by 0kolokole; 04-10-2026 at 01:51 AM.. Reason: i wrote e92 instead of e91
