BMW 3-Series (E90 E92) Forum
N54 335is misfire
| 04-06-2026, 01:48 PM | #1 |
Rep 3
N54 335is misfire
Hi all.
I've got a 2012 335is that ended up sitting for a year and half or so and I've recently pulled it out of storage. Obviously it had stale gas which I ran through as best I could short of draining the system. Car has close to 100k miles on it. Plugs were probably done at 50k. Car is bone stock except for a metal turbo intake. Anywho. Car has ran for a couple thousand miles here and on Friday felt like it went to limp mode about a mile from home. Got it home and read the code which said misfire (think it was cyl 1 and 3 but might have only been 3 based on current situation). I had spark plugs sitting around so I started with those. Pulled all the spark plugs and cylinder 3 was pretty wet. Assume it was fuel and the exhaust smells like fuel when it runs for a sec. Replaced everything started for a sec, engine code came back almost immediately. Swapped coils 3/4 and same result. Pulled plug 3 again and it's wet, not drowning. I'm assuming I have bad fuel injectors. Index is 9 on these. Seems as though this is somewhat common and gonna guess stale fuel might have contributed. Any other thoughts before I drop some $$$? I can get by replacing injectors 1-3? Should I replace coils while I'm at it? Is there anything else I need to do after replacing? Don't suggest a o2 sensor please. Thanks. |
| 04-06-2026, 03:01 PM | #2 |
![]() 557
Rep 1,308
I wouldn't worry about coils, i believe you can send in your injector for rebuild.. be a fraction of the price then a new one! I would just send in the one that is acting up. Are you getting a rich code?
| 04-06-2026, 03:08 PM | #3 |
Rep 3
No rich code. Just a cylinder 3 misfire. When I pulled it, it was definitely a lot wet. Bad enough I'd hate to drive it long. And misfiring enough that I immediately felt it.
Problem with a rebuild is time. I am assuming it'll take a couple weeks. I might pull the first bank, and send em in for a rebuild and do the second bank at a later point if that fixes everything up. Getting to em is pretty easy. |
| 04-06-2026, 03:13 PM | #4 |
Rep 3
Also seem as though rebuild may not be an option for the earlier versions of the injectors (I have index 9). Found one place and they say:
Important BMW Piezo Injector Service Notice This service is intended for BMW Index 11 and 12 piezo injectors only Earlier index injectors are not supported due to known failure rates |
| Bookmarks |
