The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > 5W 20 vs 5W 30 oil
      04-05-2026, 10:44 AM   #1
moderat0r
Drives: BMW e90 323i sedan
Exclamation 5W 20 vs 5W 30 oil
hello,
I bought 5w 20 full synthetic by mistake instead of 5w 30 full synthetic , I cant return it anymore
Brand/product name - Pennzoil Platinum Synthetic 5W20 Motor Oil 5L
Car is being run on 5W 30 full synthetic for few years
can I use 5w20 for one year or so?
is that going to affect anything ?
I am in Detroit/Michigan region weather zone
N52 engine PG77
124K miles on odometer
323 E90
year 2011
Thankyou
| Model 323i U1 | Year 2011 SEDAN | Development Code E90 (MUE) | Type PG77 | Miles 95000
      04-13-2026, 02:58 PM   #2
lookalikehuuh
Drives: 2006 330i, 2007 335i
I would not put 5w20 in a car that wasn't designed to run it.
A car designed to run on 5w30 has larger tolerences in important engine parts like rod, bearing, main bearings, etc. If you use a thinner oil, its very likely you won't produce enough oil pressure to properly lubricate the engine and may experience engine failure. Espeically with the wear that would be associated with 120K+ miles.
Don't let $30 worth of oil compromise your entire engine.
