TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Tire pressure warning nightmare please someone help! :-(
      03-29-2026, 11:51 AM   #1
BimmerGuyHere
BimmerGuyHere's Avatar
63
Drives: 2008 BMW 328i Coupe
Question Tire pressure warning nightmare please someone help! :-(
Hey!
I have a 2008 BMW 328i 6 speed manual Coupe.
When I had run Flats on it I didn't have this problem now I put four brand new tires on it and if one is low then it shows all of them to be low!
It's very strange then I'll air one up and then it's all good and then reset it.
Really I would like to get rid of the system altogether what is the best way without pulling up any more warnings, should I just remove all four sensors or is there some type of hack?
I do have the BimmerCode app and a very good OBD that has some tire pressure settings as well.
Thanks in advance...🙂
      03-29-2026, 12:33 PM   #2
TunafishE93
Drives: BMW 335i
So the system warns you that a tire is low and goes off when the tire is aired up.. my solution would to keep the tire aired up and keep a perfectly working system.
BUT here you go
https://www.e90post.com/forums/showthread.php?t=1191366
      03-29-2026, 12:36 PM   #3
BimmerGuyHere
63
Lol!!
But why does it show all four to be low I read somewhere it's because it needs to be recalibrated once you put the air in and set with the new values?
      03-29-2026, 12:37 PM   #4
BimmerGuyHere
63
BUT here you go
Honestly I would just like to get rid of this whole system without warnings!
      03-29-2026, 01:42 PM   #5
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2007 BMW 328i E91  [10.00]
2009 BMW 328i E91  [7.56]
2006 BMW 330i  [8.17]
2007 BMW 328i  [8.83]
2013 BMW X5 35i  [8.43]
2011 BMW 528i  [9.07]
Lots of good info on this... basically converting from TPMS to FTM.
https://www.m3post.com/forums/showthread.php?t=1487472
Mike K688.00
      03-29-2026, 01:58 PM   #6
BimmerGuyHere
63
Thanks for the information I've heard of that but I don't have the equipment!
Couldn't I just remove the sensors or code it out with BimmerCode?
      03-29-2026, 02:24 PM   #7
TunafishE93
Drives: BMW 335i
The link i provided has a step by step, one thing you cant do with bimmercode is edit "$2VB option from the Vehicle Order" step.. bimmercode doesn't have vehicle order edits.
Options. Get the pc software or i believe Protools has VO editing for about $200 for full license.
Again why would you not want a system to tell you have a tire psi issue? Why run around with a low tire? I would understand if it justed didn't work or was broken but just air up your dam tire! If it leaks, fix it!! Truefully in all the cars i have over the years i would get low tire pressure once a year going from summer to winter with tires that are not leaking.
      03-29-2026, 02:31 PM   #8
BimmerGuyHere
63
You're right I'm just old school back when cars didn't have any of this stuff you looked at a tire and you knew it was low you looked at a brake pad and you knew it was low you didn't need no damn sensor to tell you anything LOL
      03-29-2026, 02:33 PM   #9
BimmerGuyHere
63
Oh I forgot to ask you I'm assuming you have bimmer code app?
I know I got rid of the seat belt chime, but is there a way to get rid of that chime sound tone altogether I mean I'm still going to see the warning of low fuel Etc
it's just rather loud anyway to code that out get rid of it maybe if I can find it I'll break that little speaker out it's probably in the instrument cluster I'm assuming LOL
      03-29-2026, 03:53 PM   #10
lookalikehuuh
Drives: 2006 330i, 2007 335i
As someone who owns a car with FTM and a car with TPMS, the TPMS system is FAR SUPERIOR to the FTM system. The FTM essentially only goes off when the wheel is nearly scraping on the ground. Because its based on rotational wheel speeds instead of measuring actual tire pressures it is definitely not as accurate.
That being said, how often do you need to air up your tires, because I have probably had the TPMS go off like 3x in my car's nearly 20 year life. I even have aftermarket 19" HRE wheels with lower profile 19" tires and the TPMS system has always worked great.
I would suggest you actually fix the tire with the issue with either a properly repaired tire, or a new replacement tire. Or just have your system recalibrated.
      03-29-2026, 05:39 PM   #11
TunafishE93
Drives: BMW 335i
I have a later model but cheat sheet says SBR_BEIFAHRER_1, SBR_FAHRER_1 and SBR_BEIFAHRER_2_CD in the ABG module (likely expert mode) and likely change to "nicht_aktiv" if set to "aktiv" currently.
      03-29-2026, 06:24 PM   #12
BimmerGuyHere
63
Do you happen to have a step-by-step or a video on this I really don't want to mess it up thank you!
