The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Tire size help
      03-10-2026, 11:27 PM   #1
rgatt45
Drives: 2009 335xi
Tire size help
Looking for some input here. Is running a 245/35/18 in the front and 255/35/18 in the rear doable. On tire calculator it says the diameter difference is +.8 is that safe to run on x drive with x delete ? Fairly new to the platform so any input helps. Thanks in advanced. (09 335xi)
      03-11-2026, 04:18 AM   #2
TunafishE93
Drives: BMW 335i
You will be fine, they are actually smaller than stock so no clearance issues and a 2% difference is not going to throw any errors.
The 245/35 is a more expensive size and will have a worse ride quality.
      03-11-2026, 07:42 AM   #3
Three_thirty_I
Three_thirty_I's Avatar
South Africa
606
Drives: 2010 BMW E90 330i M Sport
It's so negligible, so won't be a problem!
Fun fact, on the E46 M Sport wheel setup, the rear width is 245 instead of 255, front is still 225 which is the same as the E90.
2010 BMW E90 330i M Sport (M)
Ex: BMW E90 330i (M) '05 (His) | (Hers) BMW E46 320i f/l (M) '03
      03-11-2026, 07:48 AM   #4
rgatt45
Drives: 2009 335xi
Thanks guys appreciate it !
