BMW 3-Series (E90 E92) Forum
Clown Nose Not Working - RESOLVED
| 03-08-2026, 12:16 PM | #1 |
Rep 20
2011 E90 328ix. My rearview mirror has the red clown nose for manual dimming. Yesterday the clown nose would not click into place. I can turn it; it won't stay in position. I opened up the mirror and found a loose spring clip which I presume is the issue.
What I can't find (and pardon me if there is an excellent post on this) is how to reinstall the clip, assuming it can be reinstalled. Below are pictures of what I found. I am hoping someone can save me from having to buy a new mirror. :-) ![]() ![]() ![]()
2011 328ix sedan 6 speed
| 03-08-2026, 04:20 PM | #2 |
Rep 20
I am going to answer my own post. It's nice to contribute for once. Taking a closer look, the clip goes around two posts. I tried both ways and figured out which way was correct. It took a little dexterity to hold the clip in place on the first picture while holding the clown nose all the way in one direction to install the other end of the clip slightly under load (second photo). The mirror went back together and it now works perfectly.
| 03-08-2026, 04:51 PM | #3 |
![]() ![]() ![]() 799
Rep 505
Nice, good on you. Do you think the spring has spring from over dimming?
My clown nose doesn't spin or dim. I figure if it wasn't alarmed why have a nose then, but that's as far as I have got. |
| 03-08-2026, 05:45 PM | #4 |
![]() 2072
Rep 2,827
Drives: 2011 328i Wagon
At least in the NA market, they all have the "clown nose" if they have the auto-dimming mirror whether they have the alarm or not. The one for auto dimming isn't as tall since it isn't needed to change the mirror angle. It just will never blink if you don't have the alarm. Up to a point, the earlier cars were pre-wired for the alarm system, but after that they weren't. I think it more-or-less coincided with the LCI changes - a cost cutting measure. But the mirrors never changed AFAIK.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
jsunma1079.50 |
| 03-08-2026, 06:14 PM | #5 |
Rep 20
I do not have an alarm and wondered why there was an electrical connector in the mirror. Krhodes1’s answer is very helpful.
While I thought I wouldn’t be able to fix the mirror I was researching swapping it out for an auto-dimming/Homelink/compass one. I thought that would be a nice upgrade. So I am sad and happy this one is fixed. |
| 03-08-2026, 06:23 PM | #6 | |
Rep 743
Drives: E70 E90 E91
Garage List 2007 E91 328xi [0.00]
2011 E90 335d [9.50] 2013 E70 xDrive35d [6.17] 2009 E91 328i [9.50] 2016 F25 xDrive28d [0.00] |
| 03-08-2026, 06:24 PM | #7 |
![]() 1080
Rep 1,031
FWIW, I don't think that on most cars or years the red "clown nose" has anything to do with auto-dimming. It's for the alarm system which you may or may not have installed and/or coded. On my car, turning the clown nose does nothing beyond removing the red plastic lens, should one be interested in doing that.
Mike K686.50 |
| 03-08-2026, 06:33 PM | #8 |
Rep 20
I am not sure what high beam assist is. That sounds interesting. I found a lot of different part numbers out there and am not sure what would have been the right mirror to buy if I did the upgrade.
| 03-08-2026, 10:07 PM | #9 | |
Rep 505
| 03-09-2026, 01:52 PM | #10 | |
![]() 2072
Rep 2,827
My 128i came with a non-dimming mirror but does have the alarm, so it had the tall one that blinked. My 328i has an auto-dimming mirror but does not have the alarm, so it doesn't. I retrofitted an auto-dimming mirror to the 128i - still blinks. The LED to make it blink is there regardless, so a clever person could make it blink with a bit of circuitry even with no alarm system if they were so motivated.
| 03-09-2026, 01:54 PM | #11 |
![]() 2072
Rep 2,827
Turns the high beams on and off for you when another car approaches. The sensor for that is in the mirror. Needs some other gubbins too. I don't recall if it's a different turn signal lever or a different headlight switch. But on one or the other is the button to turn HBA on and off.
jaffles798.50 |
| 03-09-2026, 05:15 PM | #12 | |
Rep 20
| 03-09-2026, 05:19 PM | #13 | |
![]() 2072
Rep 2,827
| 03-09-2026, 06:47 PM | #14 |
![]() ![]() ![]() ![]() 842
Rep 870
Drives: Break My Wallet
Pre-LCI models:
Clown nose in the rear view mirror indicate: 1) You have factory alarm already installed or 2) No alarm installed but the car is pre-wired for it LCI models: 1) Clown nose in rear view mirror means you have the factory alarm 2) No clown nose means no alarm (They no longer come pre-wired from factory) |
| 03-10-2026, 03:45 AM | #15 | |
![]() 2072
Rep 2,827
So more to it than just LCI or not. But I have never seen an e9x or e8x without one here in the US, but obviously, I haven't seen all of them. ![]()
| 03-10-2026, 08:47 AM | #16 |
Rep 870
Did you buy the car new or used? If used, someone could have retrofitted the mirror.
| 03-10-2026, 09:16 AM | #17 | |
![]() 2072
Rep 2,827
| Bookmarks |
