Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 2011 E93 335i Road trip
      02-09-2026, 12:14 PM   #1
n55.owen
BMW Hater
n55.owen's Avatar
16
Drives: 2011 E93 335i
What do you reccomend me to do to make my bmw ready for a cross country road trip. i’ll be driving from SF to Birmingham. i have a radiator leak im going to address later in the week. but that seems like my only huge issue atm.
      02-09-2026, 01:12 PM   #2
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
Long trip. Maintenance up to date? Definitely don't want a leaky radiator for a trip like that. You don't say how many miles are on your e93, and that could matter for things like coils and plugs.
If it were my car, I would probably get an oil change done and do a rotate & balance of the wheels. Double check my tire pressures.
      02-09-2026, 01:16 PM   #3
n55.owen
BMW Hater
n55.owen's Avatar
16
66k miles, oil change within the last 500 miles, serpentine belt replacement, aluminum coolant flange, aluminum charge pipe
      02-09-2026, 03:49 PM   #4
ppointer
60k miles is where I would replace all coil packs and plugs on an N55. FCP sells a kit for around $300, and you can DIY in under 90 minutes. Only tool I needed that I did not already have was a thin-wall socket for the plugs, as my standard plug socket would not fit.
That charge pipe is big. I have gone through three of them over the years (three different e9x's).
My niece just had her radiator die in a 2011 e91. So brace yourself, as that is not a cheap replacement. Might as well get the water pump and thermostat done, too, if you are already in there.
