BMW 3-Series (E90 E92) Forum
software for scanning
| 01-30-2026, 08:28 PM | #1 |
Rep 1
is there a software that i can use my mhd wifi scanner so i don't have to chase down a cable i have a list of code i need to start going thru
2a9e 2a9f 2aa0 2aa1 2aa3 2acb 2b2c 2cfb 2d09 2deb |
| 01-30-2026, 09:29 PM | #2 | |
![]() ![]() 3853
Rep 5,142
https://bmwfault.codes/Lookup As example, if you want the definition of "2ACB" fault code: 2ACB | DME: DME master relay, activation | msd80 | Engine electronics | View Here is the link for the Fault Information sheet for that fault (Fault Details, including "Service Notes": https://bmwfault.codes/DiagView?id=M...E2MzYwMzIwNQ== Your DME variant is MSD80, so for any DME Fault, see that line. As for 2ACB fault, an issue with DME Main Relay activation usually causes "Crank, NO Start", because the DME is NOT powered when Ignition is on, resulting in NO timing of Spark or Injector Pulse, hence "Crank, NO Start". I would suggest posting back with the following: 1) Last-7 Characters of your VIN; 2) Primary issue, such as "Crank, NO Start"; 3) Make/Model of any Scan Tool or diagnostic software available; if MHD, please attach screenprints or photos of faults read; 4) If you have a Multimeter to test wiring/ electrical components (~ $10 Amazon or HFT); With that information, we can suggest Next Steps. George |
Ohio Enthusiast368.50 |
| 01-31-2026, 07:22 AM | #3 |
![]() 369
Rep 277
Deep OBD is a free Android app that is basically ediabas on mobile. I use it with a THOR Wifi dongle and it works great for reading and deleting codes (despite a very clunky UI). Haven't used it for other things.
| Bookmarks |
