BMW 3-Series (E90 E92) Forum
N43 exhaust smoke
| 01-27-2026, 08:20 AM | #1 |
Rep 7
N43 exhaust smoke
Good Afternoon,
My car is a N43B20A E90 320i (2007). The exhaust pipe smokes at operating temperature (it also smokes when cold, but not as visibly). Unfortunately, there are no really knowledgeable mechanics in the area, and so far they haven't been able to help much with this issue. Three mechanics said that they think it's normal, but I don't agree. There is oil consumption, roughly 1 l/10,000 km. Could the smoke be caused by a tear in the PCV valve membrane? When I remove the oil filler cap, I can feel a strong vacuum, the engine starts to shake and the RPM drops, and it may even start to smoke more. Parts replaced recently: timing chain/tensioner, vanos unit, vanos solenoid, thermostat, 2 injectors, an O-ring at the oil pickup tube; oil pressure has been fine since then. Also received a software update. I'm not a mechanic, so I apologize in advance if I write something stupid. Thank you! |
| 01-31-2026, 09:18 AM | #3 |
Rep 7
Thanks for your reply. I tried to make a link about the smoke with warmed up engine:
https://photos.app.goo.gl/iyxHFzRWui9kVzey5 I checked the breather hose, is it normal to have this amount of oil in it? https://photos.app.goo.gl/mv2mEXKSwfSKXiW99 |
| 01-31-2026, 02:45 PM | #4 | |
![]() ![]() ![]() ![]() 499
Rep 760
| Bookmarks |
