BMW 3-Series (E90 E92) Forum
Would be spark plugs fix this N55 misfire?
| 01-25-2026, 06:38 AM | #3 | |
![]() 3985
Rep 2,145
Google'd came up with
| 01-25-2026, 10:45 AM | #4 |
![]() ![]() ![]() 1860
Rep 14,850
my thoughts are that plugs would not fix the issue. maybe coil packs, but if me, I would truly not want to damage the cats, they cost more than the value of the vehicle to replace at this time...
| 01-25-2026, 11:07 AM | #5 |
Rep 3,574
Most of us own code readers, they come in a great range of capabilities and prices. The first thing I would do for a misfire is to inspect the coils and spark plugs for oil. Don't just assume it's a spark plug or coil and replace everything, you're not doing anything but throw parts at it without investigating the actual problem.
| 01-25-2026, 06:07 PM | #7 |
Rep 6
| 01-25-2026, 06:09 PM | #8 | |
Rep 6
| 01-25-2026, 06:10 PM | #9 |
Rep 6
I actually did do a cat delete and have a down pipe so I’m not sure about any other cat that could be on the car
| 01-25-2026, 07:00 PM | #10 |
![]() 2627
Rep 4,527
If you're tuned you should automatically have fresh coils and plugs at all times. There are just too many variables to be running sub par hardware and it's impossible to diagnose when there is deferred maintenance on top of issues.
That being said, none of this seems to be a spark plug issue. Pull them out and see if any are full of fuel. This is much more likely an injector issue. A 3 second google search points in the direction of a thermostat issue for that last code. |
| 01-26-2026, 02:13 PM | #12 | |
Rep 6
| 01-26-2026, 03:29 PM | #13 |
![]() 2627
Rep 4,527
| Bookmarks |
