BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 2006 330xi transfer case problem
      01-21-2026, 08:08 PM   #1
treycullison57
treycullison57's Avatar
9
Drives: 2006 bmw 330xi manual
I bought a 2006 bmw 330xi with a manual transmission and I am getting error lights showing brake light, abs light, wheel sensor light, and triangle light. The car is now only rwd. I am getting multiple codes.
539E VTG
5F13 DSC
5F39 DSC
A3B2
E194
9CC1
I replaced the transfer case actuator and tried to recalibrate it with my launch scanned. I thought the bmw software to do it. I kept getting the error resister invalid and I wasn’t able to calibrate the actuator.
Is anyone able to help me, I really wanted to get my awd working before it snowed but I’m not sure that’s going to happened
Thanks!
      01-25-2026, 02:34 PM   #2
ctuna
Drives: 325xi 06 wagon MT
There is and entire x drive sub forum here.
xdrive sub forum in the following link
https://www.e90post.com/forums/forumdisplay.php?f=16
https://www.e90post.com/forums/forumdisplay.php?f=197
bmw boards and links
https://www.bimmerfest.com/forums/forumdisplay.php?f=99
https://www.e90post.com/forums/forumdisplay.php?f=27
https://www.e90post.com/forums/forumdisplay.php?f=122
https://bimmerretrofit.com/store/
https://www.e90post.com/forums/forumdisplay.php?f=378
https://www.e90post.com/forums/forumdisplay.php?f=368
      01-25-2026, 02:35 PM   #3
treycullison57
9
Thank you very much!
      01-25-2026, 02:39 PM   #4
ctuna
If you can you are better of getting a copy if BMW Standard Tools
and Ista D which uses a windows laptop and K/D can cable
See the coding subforum for more info on this.
Also the info in the attached link will be enlightening
      01-29-2026, 08:06 PM   #5
cosmo325xi
Drives: 2006 BMW 325xi E90
I have the same issue and am replacing the motor. Did you end up getting it calibrated?
      02-02-2026, 05:20 PM   #6
treycullison57
9
No I have not been able to figure it out
