BMW 3-Series (E90 E92) Forum
Lumbar suport adaptation
| 01-20-2026, 05:59 PM | #1 |
Rep 13
Hi, I recently bought a full leather interior for my BMW e90 and the set that I got have seat heating and lumbar adjustment. My original seats had only heating and no lumbar adjustment and I would like to make it work since right now only the seat heating works. Dose anyone know what do I need to do in order for the lumbar adjustment to work?
| 01-20-2026, 07:42 PM | #2 | |
![]() 2072
Rep 2,827
Drives: 2011 328i Wagon
For anyone contemplating retrofitting rather than swapping seats, the seat trims have the hole for the lumbar switch half-cut from the back, easy to finish cutting it out, and the mounts for the switch is already there too. I got all the parts to do both seat for $100 or so used. Pads, wiring harness, and switches.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
Mike K686.50 StradaRedlands11290.50 |
| 01-21-2026, 02:09 AM | #3 | |
Rep 13
| 01-21-2026, 03:53 AM | #4 |
![]() 895
Rep 3,793
search on this forum, i has few topics about this hack
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
| 01-27-2026, 12:43 PM | #5 |
![]() 2072
Rep 2,827
Sorry, I don't have any handy. I used the old online info site that got taken down since. You could make a new post asking for them, someone will post them for you.
| 01-27-2026, 12:46 PM | #6 |
Rep 13
I managed to find them in a YouTube video, fi anyone needs the link to the harnes diagram just ask
| 01-27-2026, 01:48 PM | #7 |
Rep 469
Drives: '11 E93 M3 6MT, '08 E92 335Xi
I swapped the seats in my e92 335xi and rewired it this link. Includes wire connector info
https://zpost.com/forums/showthread.php?t=1637489
Pete
StradaRedlands11290.50 Imuboys5.00 |
| 01-27-2026, 03:31 PM | #8 | |
Rep 6,827
Drives: 2006 BMW 330i MT
Garage List 2007 BMW 328i E91 [10.00]
2009 BMW 328i E91 [7.56] 2006 BMW 330i [8.17] 2007 BMW 328i [8.83] 2013 BMW X5 35i [8.43] 2011 BMW 528i [9.07] |
https://zpost.com/forums/showpost.ph...60&postcount=4 Basically all seats will will have wire#4 as positive for the seat. But seats with lumber will also have wire #7 or #9 for the lumbar. Depending on the age of the seats, you'll need to jump that 7 or 9 wire to the 4 wire. Very easy job, either do it properly with a soldered on terminal, or use a fast clip sort of jumper to do it. You might need to do the same with a ground wire as well, I don't recall doing that??? Here is my very low quality job that I'm not happy with, but it works fine: ![]() |
Imuboys5.00 |
| 01-27-2026, 06:47 PM | #9 | |
Rep 13
| 01-27-2026, 07:49 PM | #10 |
Rep 6,827
Imuboys5.00 |
| Bookmarks |
