BMW 3-Series (E90 E92) Forum
Dpf light
| 12-12-2025, 01:47 PM | #1 |
Rep 3
Dpf light
Hi guys, I’ve had my dpf light come on so ive removed and cleaned along with the egr and the light reset. After about a week it popped back up. I reset the light with the icarsoft tool “replace dpf”. Is there something I’ve missed? Can’t imagine it’s blocked back up that quickly.
(2012 318d n47 engine) |
| 12-20-2025, 03:39 AM | #3 |
![]() 899
Rep 3,799
if you never replaced the thermostat and glow plug relay with glow plugs you will never get regeneration cycles
check your engine coolant temp during driving
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
| 12-20-2025, 07:08 AM | #4 |
Rep 3
| 12-20-2025, 11:10 AM | #5 |
![]() 3619
Rep 4,527
What fault codes do you have?
With dpf issues, it's rarely actually the dpf that's the problem - it's something upstream either making too much soot for the dpf to handle, or something blocking regens from running (glow plug controller, coolant temperature, etc) |
| Bookmarks |
