BMW 3-Series (E90 E92) Forum
E91 Sunroof Issues
| 02-17-2025, 07:57 PM | #1 |
Rep 5
E91 Sunroof Issues
Hello,
It seems like I have had the worst luck with this new to me E91. The day after I bought it, the starter went on it. I had to replace that on my driveway with the cold/snow and it wasn't fun to say the least. After I replaced the starter, all was well until the first snowfall/rain. After that I noticed that there was water pooling in my passenger and rear foot wells. I checked under the hood and noticed that there were a bunch of leaves by the cowl which had slipped under the grate on the passenger side. At this point I thought the water was coming in from the HVAC system since the drain on the passenger side was clogged. The A-piller and headliner were dry. I was able to get the car into my garage and I spent a few days with the carpets pulled up and a leaf blower to dry everything out. After cleaning out the drain in the cowl, I thought all was well. Unfortunately, the passenger foot well was wet once again after another snowfall. This time I wanted to check everything as drying out the carpets in -10+C weather here in Southern Ontario isn't fun. With the car in the garage, I decided to test the sunroof drains to rule them out. I poured water in the sunroof track at the front and everything seems to be draining fine. The leak itself was coming from a gap in the passenger door vapour barrier. The water in the foot well area is now frozen which left a trail that showed where the water was coming from. The issue I am now having is that the sunroof isn't closing. From the halfway open position, it would get close to closing and then go back to its previous position. After reading up on it, it was likely due to the sunroof needing an initialization (probably due to me disconnecting the battery when removing the passenger seat to dry the carpets). At this point I do not have the sunroof error message on my dash. I held down the sunroof button to relearn the positions, but when the roof is almost in the complete open position, it seems to get "stuck" and the initialization stops. I now have the sunroof error in my dash, and the roof itself is still open. The control for closing no longer works, and the open control only moves the glass back for a sec before I hear a sort of crunch and the roof stops. It sounds like the roof is getting stuck on something which is preventing it from opening fully. I'm wondering if there was any water that possibly froze in the tracks from when I was testing the drains, or if there is anything obvious I can check. Tomorrow if I get some time, I will try the manual closing of the roof so that I can at least take the car outside. I just seems like it will never end with this car. |
| 02-18-2025, 12:44 AM | #2 |
Rep 6,827
Drives: 2006 BMW 330i MT
Garage List 2007 BMW 328i E91 [10.00]
2009 BMW 328i E91 [7.56] 2006 BMW 330i [8.17] 2007 BMW 328i [8.83] 2013 BMW X5 35i [8.43] 2011 BMW 528i [9.07] |
My first guess is ice, but it is just a guess...
| 02-18-2025, 08:45 AM | #3 |
Rep 5
I'm thinking ice as well and wanted to pour some hot water in the tracks.
The issue is that it's still -15C here and I don't want to further exacerbate the issue. We might finally get a couple days above freezing next week which will hopefully help. For now I'm going to try and closing the sun roof manually. As per typical BMWs, the tool kit is MIA in this car. Thankfully from what I'm reading, it is a standard hex drive to close the sun roof which I should have. I would like to replace the toolkit, but is the dealer the only option? |
StradaRedlands11290.50 |
| 02-18-2025, 09:05 AM | #4 |
Rep 631
Drives: 2011 e91 328i RWD
Sorry for your woes. Here's links for the sunroof crank tool. It's not very pricey:
https://www.ebay.com/itm/226036271711 https://www.bimmerworld.com/Tools/BM...r-Sunroof.html |
StradaRedlands11290.50 king_khan4.50 |
| 02-18-2025, 08:48 PM | #5 | |
Rep 6,827
| 02-19-2025, 08:42 AM | #6 | |
Rep 5
****EDIT**** I just found this thread which has a picture of what is included: https://www.e90post.com/forums/showthread.php?t=238198 Looks like the LCI cars actually never came with the sunroof tool or the wrench. So in reality, I'm actually just missing the screw driver, but I still want to complete the toolkit. Otherwise the empty spaces make it look like I'm missing parts. This is what I plan to do for now. Last edited by king_khan; 02-19-2025 at 08:49 AM.. Reason: Found the thread with my answer |
| 02-19-2025, 03:16 PM | #7 |
Rep 631
My kit has a double ended screwdriver, the crank (that I bought after I bought my e91, a 10mm & 13mm combo wrench, the tow hook (or engine lift) and a spot for a locking lugnut adapter socket.
I also carry a Harbor Freight scissors jack, a breaker bar, an Ancel BM700 scanner, a mini compressor, a cheapy tire repair kit, a jumper pack (under the passenger seat) and assorted other sockets and e-torx stuff in the under cargo areas in the trunk. I only carry my full size spare on long trips. Here's a generic web image, mine's slightly different. |
| 02-20-2025, 02:29 PM | #8 |
Rep 5
Well I can't seem to catch a break. I tried to manually close the roof today and the hex "bolt" to manually move the glass is completely stripped. I thought I had the wrong size of hex bit and tried a few before taking a closer look.
So one of the previous owners also had issues with the sunroof. I see red paint markings on the sunroof cassette and the motor which tells me they might be replacements from a junkyard. I have to source another motor just so I can close the roof manually until I can investigate further in the spring/summer. This one seems to be working, but the fact that I can't close the roof manually makes me want to replace it. Are there any caveats with finding a replacement? |
| 02-03-2026, 09:19 PM | #9 | |
Rep 1
any update 1 yr later?
I have a backup motor that isn't stripped so I can at least get it closed, but I'm not sure if I should attempt pressing the button with the other motor attached, worried it might try to brute force whatever the issue is that's causing the weird movement and dash error msg. Interested to hear how the rest of your experience went. I really just want my shade panel to move, I don't even care much about the glass at this point ![]() |
| 02-04-2026, 09:02 AM | #10 |
Rep 1
Hello, came to this page with the same kind of problem, my e91’s sunroof doesn’t want to fully close its back glass from the tilted position, makes the same cracking noise every time i try the recalibration and doesn’t solve anything. I’ve read online that sometimes it’s caused by a voltage problem or if the battery was recently disconnected or replaced, wich on mine it was. I think it needs an overall new motor and then to be recalibrated. At this point i only want to be able to use the shade only and to get rid of the error in my dash.
| 02-05-2026, 05:00 AM | #11 | |
![]() 191
Rep 75
I had issues with my E91’s pano roof and I ended up replacing the whole thing with a junkyard unit. I believe the X3 pano roof should plug and play if you can’t find an E91 locally. Last edited by boringcarenthusiast; 02-05-2026 at 05:09 AM.. |
Mike K686.50 StradaRedlands11290.50 |
| Bookmarks |
