Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > E91 N54 swap—ideas for 425 hp goal
      08-31-2024, 09:41 AM   #1
CoralRed
Drives: e36/7, e91x2, e90 335i, G01 X3
Hi All!
I’m in the planning stages of N54-swapping my 2011 auto e91. I got super lucky with the donor—- a 1-owner 2008 AW over Terra manual 335i w/108k miles.
My overall goal for the build is a car that is sorted and (as) reliable (as an n54 can be) but natural I’d like to boost the performance. Nothing crazy and I want to use quality parts. My Hp goal is somewhere around 400… let’s say somewhere between 375 and 450. During the build the usual N54 issue areas will be addressed and it’ll get walnut blasted.
I owned a 135 for 16 years so I’m very familiar with the platform but my car was all BMW parts so I’m pretty new to the n54 tuning scene.
My thoughts are:
-new turbos. Either BMW or RB (probably billets?)
-tune: MHD?
-intercooler?
-catted down pipes (VR?). My county does emissions testing so probably need the cats
-intake? My 135 had AFe that worked well for me.
-oil cooler?
-performance radiator?
-anything else I might be missing?
I’m in the process of doing some digging in my end as is the expert doing the build but wanted to get some thoughts from the n54 tuning community in case there’s something I’m not considering.
Thanks!
      09-01-2024, 07:06 AM   #2
oVeRdOsE.
oVeRdOsE.'s Avatar
4733
Drives: F25 E91N54 Audi Avnt Cayenne
you can go OEM hybrid or RB.
If you have the budget single for sure, makes the car more reliable (if done correctly), less heat, better sound, less torque on low rpm so easier on the engine.
I mean, the engine will be out, this is a good ''while Im there''
-tune: MHD?
For your goals, yes 100%.
-intercooler?
This one can be put on hold and you can do some loggin to see if temps are fine with OEM. But always a good idea, a 5'' stepped will be enough. 7.5'' are too big for your goal
N54 likes downpipe, and some flash tune highly recommend this
intake and turbo inlet. Try to find one that still had the air duct.
-oil cooler?
on all tuned N54 yes, use OEM used, they work fine and you're sure it will fits.
on boosted TT always a good idea, but this is mainly for reliability than cooling performance. Since OEM-like always separate where the plastic plenum meet the metal rad.
injectors, coils, sparkplug, latest HPFP, crank belt guard, metal pcv valve, catch can high side at least, water pump & thermostat if old; might be a good idea to add in the budget.
Transmission support are not the same if you want to keep the 6mt, a bit of fab there, nothing crazy.
no need for a LPFP for 450bhp.
      09-01-2024, 02:43 PM   #3
suspect
53
Drives: car
Originally Posted by CoralRed View Post
Hi All!
My thoughts are:
-tune: MHD?
-intercooler?
-oil cooler?
I’m in the process of doing some digging in my end and the shop doing the build is a huge help as well but wanted to get some thoughts from the n54 tuning community.
Thanks!
MHD stage1+ 98RON(93OCT) with 5.5" intercooler will give you 400bhp.
      09-01-2024, 10:01 PM   #4
lookalikehuuh
Drives: 2006 330i, 2007 335i
Keep in mind that High flow catted DPs won't be able to pass an emissions test. You will get codes for catalyst below efficiency even with the best catted DPs. In other words, when its time for emissions test you will have to swap the in the original cats before the car will pass an emissions test.
I personally use the VRSF High flow catted DPs because I hate the smell that cars with no cats have, plus I don't need another reason for the police to pull me over.
      09-02-2024, 08:19 AM   #5
oVeRdOsE.
oVeRdOsE.'s Avatar
4733
is that stringent?
swapping downpipe for emission is not an easy job !
maybe go single exit (for that L6 sound) and flange 1 pre cat where it's easy to swap, and daily the car with a test pipe.
      09-02-2024, 09:50 AM   #6
CoralRed
Thanks all, for your thoughts so far!
For the turbos: does anyone make a hybrid OEM set up? I hadn’t thought about doing a single (I thought they were for high HP applications?) but I’d probably like to leave it closer to stock. Plus, I’d probably rather spend the $$$ elsewhere… I.e suspension, interior swap. But I’ll check it out!
For the downpipes…. I definitely wasn’t aware the catted pipes may still pose an issue… I don’t want to have to change them out. Texas DOES allow for one monitor to not be active so that may be an out…
      09-02-2024, 03:03 PM   #7
oVeRdOsE.
oVeRdOsE.'s Avatar
4733
if you go on speedtech website, you'll see tons of single turbo choice, and some of them is to keep the power close to stock.
Depending on what you do, and your engine mileage, this can be debatable going small single turbo is it's more or less expensive than upgraded twins on long run.
everything is simplier, you even can get some turbo no coolant lines. Youll have only 2 O2 sensor instead of 4.
The wastegate will be external, so bye the rattle.
Intake is simpler, you don't gave intakes anymore
No more oem vacuum lines, in fact you reduce a lot the vacuum line qty.
Less heat.
Ill go for a small bottom mount.
A lot of space for future improvement. Power is a drug, and knowing those engine can put down shit ton of power, swapping a turbo is a somewhat easy upgrade.
up to you, going into a such huge project, you might rethink. OEM suspension on those E90 are already very very good. BMW nailed it.
For hybrid TT, back in the days there was a kit that you can DIY, you mainly upgrade the cold side and wheel, keeping the hot side the same and change the waste gate actuator.
      09-02-2024, 04:41 PM   #8
lookalikehuuh
Originally Posted by oVeRdOsE. View Post
is that stringent?
Oh yeah its crazy how stringent the catalyst system can be. My car has zero smell, zero soot or anything, but the car will trigger the catalyst below efficiency code within 100 miles if I remove MHD from the car.
oVeRdOsE.4733.00
      09-09-2024, 11:27 AM   #9
CoralRed
Thanks all!!
      10-25-2025, 11:07 AM   #10
CoralRed
Hi All…
Over a year later and I’m finally about to start ordering parts lol
I’m going with RB billets and inlets.
Still working on a (probably) 7.5 intercooler but that too biggest outlying questions are:
1) do I need a stage 2 LPFP??
2) The blasted downpipes. As I mentioned, my county does OBD2 emissions testing. I really don’t want to have to mess with making it emissions compliant every year and DP fixes aren’t an option for me. So, I was thinking of just going with the AR Design high-flow catted downpipes. But it seems like that they still won’t have all monitors “ready.” We only allow 1 to not be ready. Has anyone passed with high flow DPs? Or are they really not any better than catless? I know the stock DPs are super restrictive but I’d rather lower my power goals…
      10-25-2025, 11:57 AM   #11
onebluemcm
onebluemcm's Avatar
458
Drives: roads less traveled
2007 E85 M  [0.00]
2007 E86 M  [0.00]
2012 E91 335xi  [0.00]
Sounds right in line with what I have done with mine. Similar mileage too - engine has 111k on it now. Was swapped into the '12 E91 with about 97k, I just got through with a 6MT swap and a TON of other updates as a matter of addressing things on the basis of age and wanting reliability.
Rob is great, so great choice there. I also did OEM Billets turbos + RB inlets. I went with the Wagner EVO1 FMIC - with essentially stock turbos and a self imposed limit of 93 octane, I didn't think anything bigger was needed. Stock outlets. aluminum charge pipe of course. Turbosmart Kompact diverters, plumb back configuration. Burger high and low side catch cans.
Gutted OE DPs but I added in a "dummy", non-monitored high flow cat in the exhaust. Cobb 2-into-1 3in exhaust. I added the cat (cool tech, from these guys: https://acathb.com/?srsltid=AfmBOoq2...iZvlNsC9T4hJOg) in the exhaust with v-bands, and had to modify the rear part around the subframe due to the wagon configuration, but it's all good.
I don't think you need a different LPFP, just a good functioning one.
I have heard the same about the spendy high flow catted aftermarket DPs. They don't seem to be guaranteed to bass emissions. If you have to run stock DPs, that's your main bottle neck. Maybe run it by Rob, but I'm not sure the full benefit of inlets would be achieved, and from a tuning perspective, I can tell you inlets were a bit of a wild card. Assuming you go with MHD still, the PTS tunes do not account for inlets on top of FMIC and DPs. I've been working with Ken/Wedge Performance on some tweaks for inlets.
I need to create a thread for what has been done with my car - it's the time required that is the issue. If I can get all my photos hosted so they are easy to link, that's a start.
Good luck, it'll be a blast!
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
