Jacob.falkmfg
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Rockies / Midwest > Front suspension issues BMW E90
      05-10-2024, 06:48 PM   #1
S.Ward
Drives: 2008 BMW 328i E90
Hello, I've recently changed my front suspension ( did not change the springs ) and I have not touched the rear suspension yet. I used Koni Red suspension and I have the S704A type of suspension set up. My problem is now the ride height in the front is higher than the rear ride height. I've checked to see if my springs were seated properly and they are. My only concern is now would I have to get lowering springs for the car? or should I just buy the right, sport Koni yellow suspension for the car or would I run into the same problem.
any advise would be appreciated thank you.
2008 BMW 328i with M sport suspension
      05-11-2024, 07:22 PM   #2
Podunk
Drives: 335I E90
i know this is over a year old, if you're still around, what did you decide? seems to me most replacement drop in suspension will raise of the front ( not a bad thing really depending where you live as many roads here suck and it will save your front end/ fascia and skid plate)
      04-27-2025, 11:06 PM   #3
S.Ward
if your still around I can answer this. The suspension actually ended up coming down on its own. as well, it sits at the same ride height as before. as you said it was lifted like a monster truck for a while however after some driving around it settled and seems to be doing fine 2 years later. I would recommend Koni, I haven't had any issues at all with them.
