Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Tallest tire size / Max wheel diameter E91
      11-21-2023, 02:36 AM   #1
JimLahey
Drives: BMW e91 318i LCI
Hi everyone,
I’m planning on making my E91 a little more capable off the paved roads. I want to increase the ride night as much as possible (within safe and comfortable limits ofcourse) by fitting bigger all-terrain tyres. I’m planning to buy 16” (7J ET34) style 32 wheels because I like to have higher tire walls.
What would be the biggest size tire to fit? I’ve searched a lot online, but most info is regarding tire width and bigger rim size with flatter tires.
Thanks a lot!
      11-21-2023, 06:10 AM   #2
eljay
Drives: ///M + E91
I would turn the wheel left right and look for the spot where it's at the closest distance to the fender and fender liner. That's the space/clearance with which you are playing if you keep the standard tire width. Then you need to decide how much mud and snow and ice will be there given the intended use before it destroys your liners and maybe the fender metal. Take the space that's left in milimeters and calculate the tire profile you need.
If you really want to go off the beaten path, I'd take a look underneath and protect what you can with some metal shields.
      04-14-2026, 11:44 PM   #3
hxxnqzzmdn
Drives: BMW e92n51, e61
For the OP, if you're still around, what'd you find out? I want to re-use a garage full of tires off an e61 I'm selling. The 5 series diameter's around 26" whereas most e9x tires are around 25". Am I buying all new summer and winter tires if I'm replacing the e61 with an e90??
      04-16-2026, 08:51 AM   #4
e90yyc
Art Collector
e90yyc's Avatar
2873
Go to willtheyfit.com and see how the e61 wheels compare to the fitment of the stock e90 wheels.
Make sure you accurately reflect all the details including width and offset of the wheels.
I suspect they’d physically fit without rubbing but you might be getting close. You’d also have reasonably high speedo error (4%~ low) and it’s hard to say how they’d look especially with the oversized rubber.
      04-17-2026, 09:34 PM   #5
Cloverdale
Drives: 2007 335i Jb4 & perf. mods.
A 16" wheel that fits an E91? A 17" wheel I had on an 04 325 could not be bolted to my 07 335 due to caliper clearance issue.
      04-18-2026, 01:00 AM   #6
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2007 BMW 328i E91  [10.00]
2009 BMW 328i E91  [7.56]
2006 BMW 330i  [8.17]
2007 BMW 328i  [8.83]
2013 BMW X5 35i  [8.43]
2011 BMW 528i  [9.07]
Originally Posted by Cloverdale View Post
A 16" wheel that fits an E91? A 17" wheel I had on an 04 325 could not be bolted to my 07 335.
Yeah, 16" were the standards on E9x without sport or premium packages. My '09 has 282s:
