BMW 3-Series (E90 E92) Forum
which is the most reliable e92
| 02-13-2023, 03:58 AM | #1 |
Rep 6
hey everyone so i was looking to buy a bmw e92 as my first car was wondering which model and year is the most reliable, power isnt my priority but reliability is. i have come aross a 320i mt but ive heard its quite unreliable any suggestion on which model e92 i should go for
ps:we dont get diesel once here :P |
| 02-13-2023, 11:57 AM | #3 | |
![]() ![]() ![]() 309
Rep 536
| 02-13-2023, 02:18 PM | #4 | |
Rep 6
| 02-13-2023, 02:20 PM | #5 |
Rep 6
i dont think we get 328i here but iam looking for 325i and 330i atm is there any major problems i can expect these models?
| 02-13-2023, 03:04 PM | #6 | |
Rep 536
- DISA Valves - PCV. You live in a warm climate, you shouldn't have problems 325i suffers from poor piston ring design and can start burning oil. |
| 02-13-2023, 06:15 PM | #7 |
![]() 2634
Rep 4,528
Don't they have the exact same engine? To my knowledge, both use an identical N52b30 with a different intake manifold and tune, at least in the states. I think some parts of Europe got a 2.5 N52 at some point then switched over to the 3.0 for both applications.
| 02-16-2023, 08:43 AM | #8 |
Rep 536
That's a good point. I'm not sure. I just know the 06 "325i" develops issues with gunked up piston rings which lead to oil burn. It's pretty well documented on the internet.
| 02-16-2023, 09:43 AM | #9 |
![]() 28
Rep 34
Drives: BMW E90 325i 2012 B25
N52 is great, get the 330i for b30 or 325i for b25 especially 2011 and above.
| 02-16-2023, 01:58 PM | #11 |
Rep 6,829
Drives: 2006 BMW 330i MT
Garage List 2007 BMW 328i E91 [10.00]
2009 BMW 328i E91 [7.56] 2006 BMW 330i [8.17] 2007 BMW 328i [8.83] 2013 BMW X5 35i [8.43] 2011 BMW 528i [9.07] |
Don't kid yourself, there will be a LOT of maintenance on a 15 year old BMW, regardless of the engine. Valve cover gasket, oil sump gasket, oil filter housing, accessory belt/tensioner, water pump, radiator/hoses, transmission filter and seals, alternator, starter, front suspension rebuild, rear window regulators, passenger door lock, interior door grabs, trunk wiring, rear subframe & guibos... that's not even everything! You should feel comfortable doing this work yourself, or prepared to pay a mechanic to do it. It won't all hit at once, or even right away, but everything up there will need to be done at some point.
| 02-16-2023, 04:07 PM | #12 | |
Rep 536
Here are some of my bigger expenses in USD, except Vanos solenoids and CV axle, nothing else was really broken. DISA Valves are a good preventative maintenance at 120k miles, they can break and pieces end up in the engine: Tires $700 DISA Valves $660 CV Axle $450 Vanos Solenoids $300 Vanos Check Valves $80 PCV $330 Coils/Plugs $150 Brake Booster Hoses $100 Power Steering Reservoir Kit, Differential fluids, Transfer Case Fluid, Manual Transmission Fluid, brake fluid, Serpentine belt kit, gaskets, seals, single use aluminum bolts and nuts, good torque wrenches, specialty sockets, specialty tools, pressure bleeder. These things add up FAST. I still have to do oil pan gasket and start budgeting for a clutch job. |
| 03-01-2023, 09:29 AM | #13 | |
Rep 6
StradaRedlands11295.00 |
| 03-01-2023, 09:31 AM | #14 | |
Rep 6
| 03-12-2024, 04:56 AM | #15 |
Rep 3
Tought id add.
1st year with my N52B30 MT e92. So far, starter motor failed and i had to do the usual, brake disks, pads, HB pads, all 4 shocks. I do have rough idle however and the car throws some VANOS codes here and there that i should look into. Oil change every 8k and she runs hella good. |
POBEP609.00 |
| 11-23-2024, 12:29 PM | #16 |
Rep 8
Well, I heard a lot, and been an owner of, that e92 320d (180hp) is a very very reliable. I can't recall this engine mark but, it was a common one and encountered a millions of BMW powered with it.
| 11-23-2024, 03:51 PM | #17 | |
![]() 899
Rep 3,799
the only exception is EU 125i which also have N52B30 head and EU 2007+ 325i have N53B30 head so if that a person from US military and can bring US spec car with him anywhere he does duty, that one question if that a citizen of a country, then he has options above
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
whyzee1252633.50 |
| 12-10-2024, 10:20 AM | #18 |
Rep 3,574
You are looking at it wrong, it's the car that has been properly maintained and driven moderately not modded. I've owned my E92 N54 for over eight years and it has performed well as a daily driver.
| 06-04-2025, 09:31 AM | #19 | |
![]() 1597
Rep 1,035
Drives: E92/E90LCI
Most of these cars will need some work. Even if they say its 'Perfect'. Cooling system will need attention regardless. You have to DIY with most fixes unless you want to pay more than the vehicle for repairs.
Long Beach Blue E92 with Carbon Fiber Roof
Build Thread |
| Bookmarks |
