BMW 3-Series (E90 E92) Forum
Connecting High and Low Side PCV to one catch can?
| 12-20-2022, 03:33 PM | #1 |
Rep 3
Can I connect both high and low side as a input in to a OCC and have a output to the throttle body? I found a 3port OCC and have a BMS low side external pcv kit.
From reading, both high and low side just pulls from the Cyclone Oil Separators. I plan to plug head ports too. |
| 12-20-2022, 04:37 PM | #2 |
![]() 2699
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Suppose you physically can but not recommended. The low side catch can which you have pictured has a 50 micron bronze (very fine) filter for low side pressure whereas high side occ like BMS's has a much more coarse filter for higher pressure
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
| 12-20-2022, 10:28 PM | #3 |
Rep 3
I haven’t purchased the OCC yet, but the bronze filter you see in the pic would be the output port, back to the throttle body.
Plan setup: High Side (3/8 hose) & Low Side ( vacuum tube) —-> Oil catch can —> Output to throttle body. I don’t know if this would put too much vacuum on the crank case tho |
| Bookmarks |
