Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Misfire Codes, Damaging Exhaust codes, HELP
      08-03-2022, 09:46 PM   #1
Cheekrs
Drives: 335i M-Sport 6MT & TRD Tacoma
I was doing a little pull entering the freeway the other day (3/4 throttle) and the car immediately sputtered, CEL, very little throttle response, stuttering acceleration the list goes on. Rough idle around 1000rpm bouncing up and down.
I plugged in my MHD adapter and ran a quick DME scan. I have my log below from the scan. I cleared the codes and started up - no CEL, no issues, drove like a champ on the way home however I was too nervous to get on it fearing it would happen again. I had about a 30-40 mile drive home and made it there no problems. It ran like normal.
2011 n55 335i msport 6spd mt MHD stage 1 plus, bms intake, vrsf charge pipe, and most if not all maintenance caught up on. Any input or ideas what could have happened? I’d love to correct anything that may be looming to prevent this from happening again.
Codes:
7/20/2022 4:15:51 PM
- ME active codes
None
7/20/2022 4:15:17 PM
- DME active codes -
2EE0 - Combustion misfires, several cylinders:
Fuel injection deactivation.
2EE2 - Combustion misfires, several cylinders:
Damaging exhaust gas after starting up.
2EE6 - Combustion misfire, cylinder 1:
2EEA - Combustion misfire, cylinder 3: Fuel
2EFE - Combustion misfires, several cylinders:
Damaging to catalytic converter or damaging
exhaust gas.
2EFF - Combustion misfire, cylinder 1:
exhaust gas.
2F01
exhaust gas.
- ME shadow (inactive) codes
2EF7-DME: Map thermostat, activation.
      08-03-2022, 09:47 PM   #2
Cheekrs
Bump
      08-04-2022, 11:12 AM   #3
gbalthrop
Drives: 2007 328xi E91
Originally Posted by Cheekrs View Post
I was doing a little pull entering the freeway the other day (3/4 throttle) and the car immediately sputtered, CEL, very little throttle response, stuttering acceleration the list goes on. Rough idle around 1000rpm bouncing up and down. I plugged in my MHD adapter and ran a quick DME scan. I have my log below from the scan. I cleared the codes and started up - no CEL, no issues, drove like a champ on the way home...2011 n55 335i msport 6spd mt MHD stage 1...
How many miles on your current set of plugs?
Suggestion:
When you have Fault Codes that have NOT been Cleared (too late NOW ;-), take the time to read/save the "Freeze Frame Data" which is a "Snapshot" of System Conditions (such as Engine Temp, RPM, Load) at the moment a fault code was saved in DME Fault Memory.
That FF Data gives "Clues" as to the cause of a fault. ALL of your Fault Codes are related to misfire, and you had "misfire" on cylinders 1 & 3. If "misfire" occurred at high RPM/Load ONLY, the FIRST suspect is enlarged plug gap, where coil cannot provide sufficient voltage to fire plug 50 times per second at 6,000 RPM.
Since the car ran fine after turning off and back on, as is usually the case with High RPM "misfire", I would NOT have heartburn about doing WOT acceleration in 1st or 2nd (high Speed is NOT needed, just high RPM in Low Gear) at a safe spot (where you can pull over if needed) near home. This time, do NOT clear the codes until you have viewed/ saved the FF Data.
Hopefully a simple/cheap plug change (measure the gap on old plugs if they are of type where gap can change) is all that is needed.
George
      08-04-2022, 02:17 PM   #4
Cheekrs
Hey thanks for responding - the plugs are likely in need of changing. I got the car with 75k and had no info on when they were changed. Been thinking about trying the “colder” plugs. Any other suggestions?
I’ll definitely be sure to record everything if it happens again.. it’s definitely got me paranoid. I’ll do some local laps and see how she fares.
Thx
      08-04-2022, 05:48 PM   #5
Serf27
Serf27's Avatar
2980
Drives: 335i
Not sure what mhd stage 1 compares with jb4, but my n54 with standard plugs on jb4 would only last a few months.
Went 1.5 step colder and some dielectric grease and no more random misfires at wot.
Dielectric grease in the coil boots help too.
      02-04-2025, 05:07 PM   #6
lilX3
lilX3's Avatar
Drives: F25 X3
I know this is a late reply but did replacing the sparkplugs work? Im having the same issue with my 2013 X3 N55 with 98k miles right after i installer my cold air intake. Thanks any insight helps
      05-25-2025, 12:07 AM   #7
kaidxnj
Drives: 2012 bmw 335i
I just replaced mine and now i’m having these issues aswell as some others with vanos, i didn’t check the gap size on mine, the website said they were gapped already so i assumed they were. not sure what’s happening, i also didn’t code the fuel injectors as i only ran it for it to idle out of curiosity.
      04-16-2026, 01:37 PM   #8
jorgemedina_04
jorgemedina_04's Avatar
Drives: bmw e92 335i 2012 (N55)
Did you solved this problem?
Codes:
- ME active codes
None
exhaust gas.
exhaust gas.
2F01
exhaust gas.
I am having almost same but with cilinders 6 and 1, what it would be, what did works for you?
Tags
335i, cel, e90, idle, injectors, limp mode, mhd, n55, rough, tune
