The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 2007 E92 335i - White smoke out of intake
      07-18-2022, 03:38 PM   #1
REAXT
Drives: BMW E92 335i
Hi guys,
Hopefully someone can shed some light on this.
Started noticing white smoking coming out of my the rear intake cone on startup, and revving.
There is nothing coming out of the front cone.
Anyone got an idea what could be causing this?
Video with the cone removed:
https://www.youtube.com/shorts/SYH8hTlTRi0
Video with the cone installed:
https://www.youtube.com/shorts/_kQrJVjeaMs
Current Mods
Pure Turbos Stage 2 DD 450-600
VRSF 2'' N54 high flow silicone inlets
VRSF N54 Catless Downpipes
Wagner Evo 1 Competition Intercooler
BMS N54 Dual Cone Performance Intake
VRSF Chargepipe
Turbosmart BMW N54 Plumb Back Recirculating BOV
Fuel-It BMW N54 & N55 Stage 2 LPFP Low Pressure Fuel Pump
RB BMW N54 PCV Valve
3.5 Bar TMAP
Index 12 injectors
New HPFP
      07-19-2022, 12:11 PM   #2
iqraceworks
iqraceworks's Avatar
2218
Drives: 2007 335i
Isn't that pressurized air coming from the turbos where the BOV feeds back into the intake tube? It's going to dump the pressure from the turbos after you rev up the motor and then let off the gas....to dump pressure when you let off of the throttle.
When pressurized air goes to normal atmospheric pressure, you're going to see some white "fog" when moisture forms. No different than opening the air valve on and air compressor......
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
      07-19-2022, 05:51 PM   #3
REAXT
Yea I had initally thought that, removed the BOV connection and still saw the same.
Potentially its coming from the PCV system since it's only on the rear inlet.
