BMW 3-Series (E90 E92) Forum
Are E90 & E92 Differentials Interchangeable?
| 07-18-2022, 05:18 AM | #1 |
Rep 222
I suspect the diff on my 07 e92 335i auto is failing. Found several used ones on line like one from a 2012 e92 335xi. Are diffs from an e90 and e92 interchangeable or are they year specific, awd or rear wheel drive specific? Will I also have to swap out my rear cv axles as well?
Thanks. |
| 07-18-2022, 01:43 PM | #2 | |
Rep 1,643
2007 E92 335i MT
| 07-18-2022, 02:04 PM | #3 | |
![]() 3620
Rep 4,527
All e9x of the same spec will have the same diff, except M3; 90/91/92/93 doesn't matter, so long as the drivetrains match. You can find the diff ratio by looking up the spec of car on realoem. You can find the diff size (215L, etc) by looking at the diff gasket set on realoem. |
Jklad429.00 |
| 07-18-2022, 08:54 PM | #6 |
Rep 222
So I looked it up on several parts searches and even real oem and there are three part numbers that come up.
33107566152 33107572054 33107572055 I'm trying to figure out if a 2012 bmw e92 335i xdrive auto rear diff will physically fit an 2007 BMW e92 335i rwd auto? |
| 07-18-2022, 09:05 PM | #7 |
![]() 88
Rep 202
e90 and e92 diffs are interchangeable for cars with 6speed ZF.
2012 e92 is DCT trans, the diff is not direct fit for you without mod, the driveshaft lengths are different. it physically can bolt to your subframe, but thats about as far as you can go. |
| 07-18-2022, 09:56 PM | #8 |
![]() ![]() ![]() ![]() 391
Rep 632
Tambohamilton3620.00 |
| 07-19-2022, 02:24 AM | #9 | |
![]() 3620
Rep 4,527
| 07-19-2022, 08:15 AM | #10 |
Rep 222
Thanks all. I realize the ratio us not a big deal for me as I do mostly highway driving so going from a 3.46 to a 3.08 using a manual sorced diff may be the quickest repair for me. Those images really helped for me to identify the differences of the larger pumpkin and the small cv axle points. From whatbI gather most manuals have the larger pumpkin with the 3.08. I will lose some grunt on the local roads but the highway might be more enjoyable. Thanks all.
| Bookmarks |
