BMW 3-Series (E90 E92) Forum
No boost and loud vacuum cleaner noises
| 07-14-2022, 11:52 AM | #1 |
![]() 11
Rep 24
I can build at most 1lb of boost when the car is targeting 18. My car makes a crazy loud vacuum cleaner whine when the turbos spool. wgdc is at 99. I replaced all vacuum lines not long ago, and rechecked them. Vacuum lines are good. Intercooler piping is good. Charge pipe is on tight. I bought a new boost solenoid and tested it in both positions, no dice.
Any ideas what this could be before I take it into a shop to check for boost leaks? I am reluctant to post a log because I don't want to go WOT in this condition.
VRSF catless downpipes, VRSF 7.5 inch intercooler, ECS Charge pipe and BOV, BMS cones, XHP stage 3 TCU, MHD Stage 2+
| 07-15-2022, 09:52 AM | #2 | |
Rep 120
It definitely sounds like a boost leak if its the sound im thinking. If its a high pitched noise, then thats a blown turbo.
2011 335is 6spd - White with Black Base : 5in VRSF IC / BMS CP Raceport BOV / Arm DP / RB Inlets / JB4 w/ MHD BEF Race / Meth cm10 / Modified CDV / BMS DCI / Stage 2 LPFP / Spec 3+ Clutch / - RB 2+ Turbos SHE LIVES \ Ew @ Comic Sans
1992 NA6 Smurf miata - pretty much dead / parting out 2005 Ex 250 ninja |
| Bookmarks |
