BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Q: Port Injection injector size (42mm or 48mm)
      07-12-2022, 06:02 PM   #1
PS2N54
Drives: 09 335i
trying to get a replacement set of Bosch EV14 72lb/750cc injectors without getting direct from PR/Fuel-it/BMS
fuel-it advertises the injectors as Bosch EV14 42mm sized injectors, however when searching for such a size its not standardized and only fuel-it products show up. from what i can see 48mm is the standard cross platform size.
can anyone confirm if you have a port injector on hand the measurement between the o-rings or a bosch part#
thanks!
