BMW 3-Series (E90 E92) Forum
FBO MHD Stage 2+ verses custom tune
| 07-12-2022, 11:54 AM | #1 |
Rep 2
So what gains if any are people seeing on custom tune from Wedge and alike verses or coming off MHD stage 2+ with full bolt ons (and Inlets, outlets, etc)... on stock turbos...
| 07-12-2022, 12:51 PM | #2 | |
![]() 2218
Rep 3,816
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
darkrom305.50 |
| 07-12-2022, 12:57 PM | #3 |
Rep 941
if you run V5 e40 that will be pretty close to a custom tune. But custom tune is fine tuned to your car so dont always look at what makes more power, custom is specifically made for your engine.
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
| 07-12-2022, 02:38 PM | #4 | |
Rep 2
So what HP are you seeing on your Tune, looks like you have the exact setup I'm asking about (FBO+Inlets) and a Tune from Wedge. |
| 07-12-2022, 03:48 PM | #5 |
Rep 941
470whp
| 07-14-2022, 05:25 PM | #6 |
![]() ![]() ![]() 496
Rep 470
At this point Ken will probably send you a pre-made base map with a tiny bit more boost or timing than the MHD map which makes 5-10 more horsepower, and do 1 revision to fix timing corrections. Sure, you could target 21psi and fry your turbos, but then you'll probably upgrade them and need a new tune again (so more $$). Just some food for thought.
| 07-16-2022, 09:26 AM | #7 | |
![]() 989
Rep 3,219
The gains aren't significant, I have a custom tune and the difference is marginal compared to OTS map. |
| 07-16-2022, 09:28 AM | #8 |
![]() 989
Rep 3,219
As Ab987 said, if you plan on upgrading your turbos in the future, don't bother with the custom tune until you've got the turbos on.
| Bookmarks |
