Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Quiet muffler
      07-07-2022, 12:18 AM   #1
Vulcan50
Vulcan50's Avatar
467
Drives: e92 335i
Quiet muffler
Is there a muffler that's as quiet or quieter than stock that doesn't weigh 1000 pounds like the stock one?
      07-07-2022, 12:44 AM   #2
C4maro
C4maro's Avatar
85
Drives: 335i
      07-07-2022, 12:46 AM   #3
Vulcan50
Vulcan50's Avatar
467
Drives: e92 335i
Originally Posted by C4maro View Post
Calm down, it's part of a larger plan
C4maro84.50
      07-07-2022, 03:08 AM   #4
Saif2018
Drives: E90 335i
The stock muffler without the golf t mod is already very quiet.
1000 pounds? lol, sounds like a hair brained weight reduction scheme going on.
Why would you want to make your car sound worse than the stock muffler?
      07-07-2022, 06:12 PM   #5
R3dLeader
Drives: e92 and e93 335i
Worse =/= quiet.
How much does the stock muffler weigh?
      07-07-2022, 10:50 PM   #6
Vulcan50
Vulcan50's Avatar
467
Drives: e92 335i
I'm going to muffler delete the driver side, And want to keep the passenger side quiet. If I'm going to be modifying the passenger side anyway I'd like to do a nicer looking, lighter and equally quiet muffler
      07-08-2022, 02:31 AM   #7
autoart
Drives: 2009 335i e90 M/ 22 X3/2016 Ho
OEM Exhaust- 75lbs
      07-08-2022, 03:02 AM   #8
Saif2018
Drives: E90 335i
Originally Posted by R3dLeader View Post
Worse =/= quiet.
The stock exhaust system is already quiet with the valve active.
I've only got the Golf T mod, which is still fairly muted. If the op wants the sound of a vacuum cleaner, he bought the wrong car.
      07-08-2022, 03:06 AM   #9
Saif2018
Drives: E90 335i
Muffler delete causes drone though,
A valved exhaust system is this what you want?
https://valvetronic.com/products/bmw...muffler-bypass
      07-08-2022, 11:03 AM   #10
Vulcan50
Vulcan50's Avatar
467
Drives: e92 335i
Functionally, that is what I'm doing. And I'm aware of this setup. I've actually wanted to do this since I bought the car. But $750, they must be high
      07-08-2022, 11:32 AM   #11
Socalturbo
Drives: Subaru Legacy GT
You're going to need a custom one. You can start with the Vrsf or any aftermarket exhaust and then have a shop add in a few resonators and make it a single exit. Doubt it will be quite than stock, but that's the only way to really do it.
You can also hack up the stock exhaust to achieve the same thing but with a new muffler section.
      07-08-2022, 12:21 PM   #12
whyzee125
Drives: Dinan stage 2 335i
Best bet would be something like the eBay HKS knockoff (Beluga, M2, etc.) and then weld in some Magnaflow mufflers midstream or at least Vibrant resonators. Nothing's going to be quieter than stock but that would be significantly lighter and only moderately louder.
If quiet is very important to you (and I get it!) I'd lose the weight in the wheels and leave the OEM exhaust
      07-10-2022, 12:33 AM   #13
Vulcan50
Vulcan50's Avatar
467
Drives: e92 335i
Sounds like it's not worth the small gains. So I'm just going to basically duplicate the valvetronic, but for cheaper!
      07-10-2022, 11:49 AM   #14
Blau
J
Blau's Avatar
Drives: BMW 128i
2011 BMW 128i  [6.00]
2013 BMW X3 28i  [0.00]
Would a stock 128i muffler work? I've got one you can have fo cheap.
      07-11-2022, 12:06 AM   #15
Vulcan50
Vulcan50's Avatar
467
Drives: e92 335i
I'd guess that the stock mufflers would be similar enough to not be worth messing with.
