TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Managed to break the plastic connector of the vacuum hose to vacuum canister
      07-06-2022, 10:02 AM   #1
wind-7ar
Drives: 335i n54
Basically the title. Yeah, I know.
I know my car isn't getting any vacuum right now since I no longer have any wastegate rattle (at least there's that, haha)
My question is: Car is no longer safe to drive, right? After my fuckup I just started the car briefly and did a couple of light revving (no lights on the dash). Is this fine?
My intuition tells me that now the car at worst can make so much pressure since the wastegate is no longer controlled that it can literally kill the engine. But I might be wrong
What are your thoughts?
Have a good one guys
      07-06-2022, 11:45 AM   #2
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Opposite effect, no vacuum results in the gates staying open thus the car won't make boost. You'll eventually get an 30ff code but other than that not much risk.
You could also bypass the canister completely using a splice, car will drive fine without it.
U WOT M8?
      07-08-2022, 02:05 PM   #3
Saif2018
Drives: E90 335i
If the connection point on the cannister is broken, just replace the cannister,
It won't kill the engine, you just won't make enough boost and will likely end up with boost leak/30FF eventually.
      07-09-2022, 06:00 PM   #4
feuer
feuer's Avatar
Drives: wife crazy!
JBweld metal nipple on there.
