The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > B58 Coils vs N54 Eldors
      02-25-2022, 09:47 PM   #1
ab987
ab987's Avatar
494
Drives: 1M, 2xM3, X3M, 335i
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
2008 BMW 335i  [9.25]
2020 BMW X3 M  [9.50]
Hey guys,
Getting some fun misfires at high RPMs now that I've gone to RB Twos. I am on original coils (to my knowledge) at 100k miles and 20psi is doing them in.
For those of you running B58 coils, are they worth it? Do you have to modify them past the point of return and cannot warranty them should something go wrong? Have you noticed smoother operation at low load compared to Eldors?
I am hesitant about the B58 coils because of the cost of the adapter plate, modifying the factory VC, modifying coils, etc. If Eldor N54 coils can support 600 crank horsepower without hiccups I think that's the route I'll take.
Thanks
2011 E82 1M | 2020 F97 X3M | 2010 E90/E92 M3 | 2008 E93 335i
ActiveHybrid5 8P70H N54 Swap
S65 Main Bearing Failure
Carbahn 4.2L S65 w/ Cams
      02-26-2022, 09:17 AM   #2
iqraceworks
iqraceworks's Avatar
2218
Drives: 2007 335i
From the little bit of research that I've done on this.......the B58's and Eldors put out close to the same amount of power. I have seen guys on other forums claiming they are making 700+HP with big single turbos and Eldor coils. The B58's require some wiring changes and brackets to mount them....seems like a royal pain in the butt.
That being said...I'm running the OEM Delphi coils from FCP Euro and I should be making close to 565-575hp at the tires on an E40 mix and bigger turbos at 27psi....and I have no issues with misfires.
With 100k miles on your coils......ANY new coils are going to help big time!!
If I were you...I would just order the N55 eldors from FCP with the lifetime warranty and be done with it 👍
ab987494.00
      02-26-2022, 09:24 AM   #3
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
Thanks for the reply, are N55 eldors different than N54 eldors? I thought the two shared coils.
      02-26-2022, 10:25 AM   #4
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
Let's expand the scope a bit. Which are the best plug-n-play coils?
I cannot find any controlled testing of Eldor N54 coils anywhere. I don't quite buy into the hearsay that they are 100% the best, no substitutes.
For example, bahn's testing shows the Delphi S55 coils are the best currently-produced OE option (Eldors aren't made anymore for S55, maybe another reason to avoid them if production for N54 might also end). Is that the same coil that is also listed for our cars on realoem/FCP/ECS?
I like the Dinan coils for their color options and success of users so far, but also cannot find any proper controlled testing by them either.
      02-26-2022, 10:31 AM   #5
Saif2018
Drives: E90 335i
Originally Posted by ab987 View Post
Hey guys,
Thanks
I'd agree totally with iqraceworks, just go with the Eldors from FCP. Those Dinan ones posted in the other thread also seem fine. As stated at 100k your coils are probably toast.
No need to mess around with brackets, wiring etc.
ab987494.00
      02-26-2022, 11:39 AM   #6
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
I appreciate it, but is there any controlled testing that shows the Eldors are superior? I would be inclined to believe the Delphis would be considering they are the top S55 coil that's currently produced, and generally S55 > N54 when it comes to application-specific coils.
      02-26-2022, 12:23 PM   #7
BSM n54iS
BSM n54iS's Avatar
2699
Drives: '11 335is | '16 Macan Turbo
S55 Delphi=Dinan > N54 Eldor
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
ab987494.00
      02-26-2022, 12:49 PM   #8
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
Cool, and are the S55 Delphis the same as N54 Delphis? They are both the same listing on FCP and realoem, just wanted to make sure they are different than the old N54 Delphis
      02-26-2022, 12:58 PM   #9
BSM n54iS
BSM n54iS's Avatar
2699
Link? Pretty sure you're reading the application list which covers s55's and n54's, same coil PN right?
      02-26-2022, 01:34 PM   #10
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
https://www.fcpeuro.com/products/bmw...6153-1#fitment
https://www.realoem.com/bmw/enUS/partxref?q=12138616153
Is this considered the S55 Delphi or the N54 Delphi? I can't even find an N54-specific Delphi, so I don't know what bahn tested. I specifically want the S55 one.
      02-26-2022, 02:35 PM   #11
BSM n54iS
BSM n54iS's Avatar
2699
S55, I compared those in the Dinan thread. I actually don't think there is such a thing as the n54 Delphi anymore, it may have been years back when they were first coming out along with the s55's or something, but now it seems that 16153 pn is the one and only as far as Delphi go. Someone correct if I'm wrong
ab987494.00
      02-26-2022, 02:42 PM   #12
Rule1977
Rule1977's Avatar
Drives: 08 BMW 335I E90
I run Eldor coils and NGK 97506 plugs and have never had a misfire since I put them in.
08 E90 335i - MONTEGO BLUE
JB4/MHD E85 BEF - RB TWOS PLUS
ECS CARBON DCI - BMS CHARGEPIPE
NRW CARBON COWL FILTERS - TIAL BOV
VRSF 7.5 RACE FMIC - VRSF INLETS - VRSF OUTLETS - VRSF DOWNPIPES
BMS PEDAL TUNER - VTT DUAL CATCH CANS
3.5 BAR TMAP - NGK 97506 PLUGS
H@R SPRINGS - NRW V1 PADDLES
PFS STAGE 3 LPFP - PFS V2 PORT INJECTION
MOSSELMAN OIL THERMOSTAT
MISHIMOTO 25 ROW OIL COOLER
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 15 ROW TRANSMISSION COOLER
ZIMMERMAN DRILLED ROTORS - EBC REDSTUFF PADS
ab987494.00
      02-26-2022, 03:10 PM   #13
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
Do you know if the Eldors have been confirmed to be better than the Delphis? Because there still is no evidence that I've seen that isn't anecdotal.
      02-26-2022, 03:28 PM   #14
Saif2018
Drives: E90 335i
They are about the same, haven't seen any hard evidence either, maybe slightly better who knows, I've run them with no issues. I'd get t the Eldor ones if you can, otherwise Delphi ones will do the job fine.
ab987494.00
      02-26-2022, 03:41 PM   #15
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
I think I will go for the Delphis only because of their lack of S55 production, I am in this for the long haul and don't want them stopping production. Thanks guys
      02-26-2022, 03:42 PM   #16
BSM n54iS
BSM n54iS's Avatar
2699
Read through page 1 of the Dinan thread again and then go to a different website mentioned where actual numerical data was compiled. They are different.
      02-26-2022, 04:23 PM   #17
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
That's the site I am referring to, they never tested Eldor N54 coils despite both bahn and Dinan saying they would. Unless I'm blind.
      02-26-2022, 07:58 PM   #18
Bimmer_Bro
Bimmer_Bro's Avatar
Drives: 2010 BMW 335xi LCI
Do you plan on going more than 20psi? How much power you currently pushing?
To be honest I think you're over thinking it. With the age of your coils, a stock or light tune is going to misfire. You will be replacing plugs and coils a lot more often when tuned either way.
Many guys have had great luck with Eldor on high hp applications.
I use bosche oem plugs and coils with zero issues. (Oem turbos 18 psi)
Instagram : @Bimmer_bro
      02-26-2022, 08:09 PM   #19
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
20psi is the base map, we're planning on settling in 22psi on 93 and eventually further (25+) on full e85 when ReFlex has MHD integration. My stock coils and 1-step-colder plugs were plenty for e50 stage 2+, but if they can't keep up now on a mild tune, there's now way they will keep up making over 600 crank hp.
      02-26-2022, 08:14 PM   #20
Bimmer_Bro
Bimmer_Bro's Avatar
I am honestly surprised you got 100k on them even without a tune. They are just old. I'd go with the Eldors off fcp with free lifetime replacement. I'm sure the Dinans are good but they are new. Eldors have been used on our platform for years. Good luck with the build .
      02-27-2022, 09:14 AM   #21
iqraceworks
2218
Drives: 2007 335i
Eldors....1 step colder NGK plugs, gap them at .020".....and run it. Guys have been running that setup for ever making big power. You are overthinking things....😁
      02-27-2022, 06:54 PM   #22
ab987
ab987's Avatar
494
2010 BMW M3  [9.60]
2011 BMW 1M  [10.00]
I appreciate the responses but I want to see some testing and numbers. I'm sure Delphi and Eldor coils would work fine for my application but for those really winding it out, it would be great to know
