Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > OEM location silicone inlets vs relocated inlets?
      11-24-2021, 03:47 PM   #1
iqraceworks
iqraceworks's Avatar
2218
Drives: 2007 335i
Would I see any benefits in going from my aftermarket silicone stock location inlets to the ARM relocated inlets? I've heard pros and cons on the relocated inlets....what's everyone's opinion on them? I saw that ARM is having a black Friday sale...that's why I was asking.
Seems to me like they would be sucking in more hot air since the filters are right by the exhaust manifold, but maybe not??
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
      11-24-2021, 04:03 PM   #2
dyllan12
Drives: BMW e92 335i
It adds couple more HP when you tune it … Inlets gives the turbo better airflow
      11-24-2021, 05:30 PM   #3
iqraceworks
2218
Drives: 2007 335i
I already have inlets, a custom tune, and bigger turbos....just wondering if going to relocated inlets add anything over the standard silicone inlets.
      11-26-2021, 08:30 PM   #4
Paul375
Paul375's Avatar
Drives: BMW 2008 335i Coupe (E92)
2088 BMW 335i  [0.00]
I heard if you want big power go with relocation inlets, but you have to move the coolant expansion tank and move power steering tank also. I am worried about mine not fitting with the Tial BOV.
BMW 2008 335i Coupe - [SIZE="1"][I][SIZE="2"][SIZE="3"]Sport Package, JB4 ISO G5(Bluetooth) with MHD BEF, Vanguard Cat Back Exhaust, UUC Short Shifter, AFE Magnum FORCE Pro Dry S Intake, BMS Chargepipe & Tail BOV, NGK 95770 Spark Plugs, ECS Oil Catch Can, 19" Enkei Wheels, RB PCV External, Ohlin's Coil Covers,
      11-26-2021, 11:52 PM   #5
_N54
_N54's Avatar
313
Drives: 335d
I got the 335d coolant tank. It bolts right up to the driver side. I also got the BMS 335d charge pipe that's made to clear the 335d coolant tank. I kept the power steering reservoir at the same location by making a custom L bracket with a piece of 1" aluminum metal that's bendable.
2013 335is - sold
2011 335d
      05-03-2022, 01:25 PM   #6
Paul375
Paul375's Avatar
Where did you put the vacuum canisters, after you relocated them? Or did you delete them?
      05-21-2022, 12:31 AM   #7
_N54
_N54's Avatar
313
Drives: 335d
Deleted. Installed made no difference. Deleted and verified it made no difference.
2013 335is - sold
2011 335d
