The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Anyone getting "false knock" with a built motor?
      02-13-2021, 01:34 PM   #1
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
Since the beginning of tuning my motor after building it with closed deck, steel rods, JE forged pistoms stage 4 heads with titanium valvetrain, it's always pulled timing even with low timing, and it's been frustrating... we're at the point now where we're thinking maybe it's "false knock" so I did some googling and found some threads saying that built motors, "especially with closed deck conversions and forged pistons" cause alot of false knock. With more than enough that tuninf; new Eldor coils, new 2 step closer NGK plugs, it's hard to believe this knock is real.
Has anyone else seen that with theirs? Here's a recent log: https://datazap.me/u/terryeaton/log-...og=0&data=3-21
I found this very interesting thread and am wondering if maybe I need to replace my knock sensors with these:
https://www.german**********/showthr...-Knock-Sensors
I re-flashed with the "desensitive knock tables" and it made a difference, am seeing 0's on a couple columns now, but still some negatives in 2 and 3.
Anyone else run into this?
Thanks
2010 335XI, Carillo Steel rods, JE pistons, Closed Deck, Stage 4 race heads, 6mt, Pure Stage 2 High Flows, B58 Coils, VRSF|Vu Brothers (Ft Worth, TX)|JSRTuning,
https://youtube.com/channel/UC_kL3RvFSGv9QmTVt6787gg
      02-13-2021, 02:23 PM   #2
feuer
feuer's Avatar
Drives: wife crazy!
If you are still getting timing corrections even with desensitive knock tables probably something else is the reason. I’m assuming you have eliminated possibility of fuel issue or poor quality fuel?
      02-13-2021, 03:08 PM   #3
Saif2018
Drives: E90 335i
Originally Posted by Quick335XI View Post
Since the beginning of tuning my motor after building it with closed deck, steel rods, stage 4 heads with titanium valvetrain, it's always pulled timing even with low timing, and it's been frustrating... we're at the point now where we're thinking maybe it's "false knock" so I did some googling and found some threads saying that built motors, "especially with closed deck conversions and forged pistons" cause alot of false knock. With more than enough that tuninf; new Eldor coils, new 2 step closer NGK plugs, it's hard to believe this knock is real.
Thanks
Which fuel are you running exactly?
      02-13-2021, 03:20 PM   #4
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
I'm running PI with around 60% ethanol. Plenty of fuel, trims look good and rail pressure is good, see lot above... Thats why I'm thinking this knock is false...
      02-13-2021, 03:34 PM   #5
Saif2018
Drives: E90 335i
Mixed with 91 Oct or 93oct?
      02-13-2021, 03:35 PM   #6
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
No E8, usually around 60% ethanol.
      02-13-2021, 03:36 PM   #7
Saif2018
Drives: E90 335i
E8?
      02-13-2021, 04:03 PM   #8
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
Sorry, E85
      02-13-2021, 10:57 PM   #9
Saif2018
Drives: E90 335i
Sorry, E85
60% so it must be mixed with Gas right?
Or you on E85 only (100%)?
      02-14-2021, 02:37 PM   #10
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
No E85 is 100% pure ethanol... The pump I go to says E85 but usually the sensor says it's around 60%
      02-14-2021, 03:05 PM   #11
Saif2018
Drives: E90 335i
Have you tried a different pump, just to rule out quality of the fuel being the cause?
      02-14-2021, 03:13 PM   #12
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
It's difficult because there's not a lot of them but I plan on driving across town next time I need to fill up. The thing is, as we back of timing it makes no difference as when the timing is more advanced... Which sounds like it's false knock.
      02-14-2021, 03:16 PM   #13
Saif2018
Drives: E90 335i
Could be false knock,
have you tried running a pump map with 93oct fuel?
Just to see if timing corrections still occur,
      02-15-2021, 07:14 AM   #14
tisdrew
Drives: 2009 335i
It could be false knock. Dedicated dyno time with a set of "det cans" and competent tuner will likely be able to tell if the sensors are being overly sensitive.
I've read about BMS and VTT using customized knock sensors/tables on their built n54 motors but don't have personal experience.
"Wheels and exhaust aren't a build"
feuer4355.00
      02-15-2021, 12:29 PM   #15
FEDE/E92
Drives: 2007 BMW 335i
How aggressive is your timing? Few people use nylon washers to quite down the knock sensors. Have u tried lowering boost and going full e85 not mixing. Who's your tuner?
feuer4355.00
      02-16-2021, 07:23 PM   #16
iqraceworks
iqraceworks's Avatar
2218
Drives: 2007 335i
I would check with your tunner.....the knock sensors are picking something up. To say it's "false knock" sounds like an excuse because you can't find the real issue. Keep backing down timing until it goes away.....and see where you are at. Just assuming the sensors are wrong is a good way to destroy the motor.
This all boils down to the tuner you are using....if he's lost, find a new tuner. If you are going to the cheapest guy to save money, that's the wrong approach. There are several well known guys that do this a for a living. If your tuner can't figure it out...find someone new. That's too much money in a motor build to just roll the dice.
feuer4355.00
      02-21-2021, 02:33 PM   #17
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
But how do you tell if the knock is false or not for sure, esp when the plugs are new, new Eldor coils and lots shows all fuel trims and such are fine?
      02-21-2021, 04:19 PM   #18
iqraceworks
2218
Drives: 2007 335i
Pull the plugs, and check for signs of detonation...little black specles on the white porcelain of the plugs. If your tuner doesn't know how to read spark plugs....find a new tuner.
      02-26-2021, 05:58 PM   #19
Quick335XI
Quick335XI's Avatar
134
Drives: 2010 335xi
Plus are clean as a whistle...
latest log: https://datazap.me/u/terryeaton/log-...og=0&data=3-21
Fuel trims looks good, rail pressure, etc... kinda frustrating
Thanks
      02-26-2021, 07:06 PM   #20
Saif2018
Drives: E90 335i
Thanks
Still have some nasty timing corrections up top,
What's your tuner saying?
      02-26-2021, 08:45 PM   #21
feuer
feuer's Avatar
Drives: wife crazy!
Thanks
IAT isn’t spiking either. That would cause timing corrections too. Is tuner offering different timing mapping to remedy this or just asking to check hardware and fuel?
      03-02-2021, 11:45 AM   #22
Velocity+
Drives: 2018 M240i RWD
Take a look at your engine mounts. They could be worn, which causes the engine to move under acceleration and triggers the knock sensors.
