Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > E92 engine swap n46 to N54
      02-05-2021, 09:19 PM   #1
Asreegan
Asreegan's Avatar
Malaysia
Drives: E92
Hi all,
I've just recently converted my e92 from n46 to n54..I only managed to get hold of a e91 which everything was transferred to my e92..The issue is that e92 originally drops and raises its windows 5/6mm when the doors are opened and closed, since my wiring is from an e91 that feature doesn't operate..appear it's your guidance If I could get it to work..aside to that my central locking doesn't work as well..would it be possible to make it operate again..your guidances are very much appreciated
      02-06-2021, 01:48 PM   #2
Sav.
Sav.'s Avatar
55
Drives: '08 E92 335i
2008 BMW 335i  [0.00]
Originally Posted by Asreegan View Post
Hi all,
I would look for someone that does coding in your area, I can't imagine why this wouldn't be able to get coded in.
*Not professional advice
soon-to-be M240ix owner
      02-06-2021, 02:31 PM   #3
Ozzie335i
Drives: 2011 335i
You don't even need a local coder as this kind of stuff can be done via the net. You can do a session share with the coder, watch and speak with him, yes him, while the work is being done.
      02-06-2021, 04:07 PM   #4
Sav.
Sav.'s Avatar
55
Viable option, as long as one doesn't mind purchasing the required hardware.
      02-06-2021, 06:48 PM   #5
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
You just need a kdcan likely and have the software in your computer/laptop which you should have anyway to do it with a guy online. Or DIY it with one of the thousand videos online on how to code this stuff
      02-07-2021, 03:22 AM   #6
Asreegan
Asreegan's Avatar
Malaysia
Drives: E92
Thanx a million guys will try to get it done..fingers crossed
      03-15-2026, 12:18 PM   #7
eduardospm
Dominican Republic
Drives: BMW E90 318i 2008
Did you transferred the entire electrical wiring harness? Because I have an e90 that came with the n46b20 engine and I decided to swap to a n52b30 (I got it from a crashed car in excellent condition) but idk if the wiring harness is required bc someone told me about the fuel pump pressure would be a problem since the n46 uses a fuel pump without the EKPS module. Any advices?
