BMW 3-Series (E90 E92) Forum
MHD Stage2 much quieter than Stg0, why that?
| 11-28-2020, 02:33 PM | #1 |
Rep 12
I recently replaced my turbos and much more on my e92 n54 and noticed my car is way more quieter than it was before, MHD stage 2 was on the car before I changed so much. I thought it may because of new seals, but for logging purposes I flashed back to Stage 0 stock through MHD to keep the data logging active.
With that it is much more louder, it bangs and pops like it used to. Next to the turbos I replaced boost solenoids, coils, spark plugs, ton of seals and hoses and so on... Is that something with the wastegates? They´re not that wide open with stage 2? Even with aggresive pops and bang settings, it gets not very loud (also while normal driving). And another thing, my car never wanted to burble above 3000 rpms, even after replacing so much, never understood why...? Last edited by KnobDE; 12-01-2020 at 12:52 PM.. Reason: wrong title |
| 11-29-2020, 02:22 AM | #2 | |
![]() 989
Rep 3,219
How is your Exhaust setup? |
| 11-29-2020, 10:36 AM | #4 |
![]() ![]() ![]() ![]() 736
Rep 946
Never flashed to stage 0 but my car FBO before tuning was much much quieter than afterwards. It really surprised me how much louder and more like a tuner car it sounded like afterwards. From the spool and the wastegates, induction sound, DV’s and everything.
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
| 11-29-2020, 10:56 AM | #5 |
Rep 12
I have no idea what´s wrong then
Maybe too much psi and leaking/passing anywhere...? I logged the car with stage 2 and actual boost was always 0,2-0,3bar (3-4,3psi) behind target boost, Stage0 is fine |
| 11-29-2020, 02:43 PM | #6 |
![]() ![]() ![]() 157
Rep 518
I noticed this whenever my car would go into limp mode(turbos off). The pops and bangs sounded like legitimate gun shots. I think it has something to do with the fact that the turbos are pushing out more air when the boost is higher, or they are just drowning out these sounds completely.
| 11-30-2020, 12:57 AM | #7 |
![]() 989
Rep 3,219
| 11-30-2020, 01:02 PM | #9 | |
![]() 989
Rep 3,219
https://bmwtuning.co/bmw-n54-30ff-en...-repair-guide/ |
| 11-30-2020, 02:54 PM | #10 |
Rep 12
1. Inspect piping for the intake, chargepipe, diverter valves
As I said, I already did that. 2. Check your vacuum lines They´re all new. 3. Replace your N54 boost solenoids I did, they´re new, 2x Pierburg. 4. Adjust your wastegate actuators Turbos are new. 5. Replace your turbos That´s what I did ![]() |
| 12-01-2020, 06:18 AM | #11 | |
Rep 722
beter laat dan nooit
| 12-01-2020, 10:56 AM | #12 | |
![]() 989
Rep 3,219
| 12-01-2020, 11:40 AM | #14 |
Rep 526
| 12-01-2020, 02:34 PM | #16 | |
Rep 526
Higher the stage, higher the boost. Higher boost means closed wastegates. Closed wastegates forces exhaust thru the turbo, softening the noise. Less boost = open wastegates = direct path for exhaust. With JB4, there's a valet MAP that disables boost entirely by opening the wastegates and leaving them open. It's like Stage -1. It makes the engine sound much deeper, better, louder. Also is slightly more efficient since it reduces exhaust back pressure when it isn't' needed to spool. |
| 12-01-2020, 04:05 PM | #17 |
![]() 989
Rep 3,219
| 12-01-2020, 04:15 PM | #18 |
Rep 12
Vacuum canisters are fine, on of first things I checked
![]() But compared to other cars with Stage 2 mine is way different, but I guess there´s still a boost leak, here in Germany I couldn´t find a proper shop yet, which could do me a boost leak test, BMW said I should give them my car there for a few days. Somehow I got the feeling they do not really know what to do then.. |
| 12-01-2020, 05:16 PM | #19 |
![]() 2701
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Do you have a decibel-O-meter on your phone? I'm gonna have to see some numbers here..
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
| 12-01-2020, 05:24 PM | #20 |
Rep 12
I can make you a video in neutral, if you want
For comparison... anyone in here got a vid with stage 2, downpipes and oem exhaust in neutral or while driving? Last edited by KnobDE; 12-01-2020 at 05:30 PM.. |
| 12-06-2020, 01:59 AM | #21 | |
![]() 989
Rep 3,219
If the turbos are new, you almost certainly have a boost leak somewhere, 3-4 psi off target isn't normal, 1-2 at worst. Definitely need to do a boost leak test. The turbos you replaced, they stock OEM ones? Did you have a local garage install them or did BMW? Last edited by Saif2018; 12-06-2020 at 02:14 AM.. |
| 12-07-2020, 12:20 PM | #22 |
Rep 12
These are OEM MHI (Mitsubishi) turbos.
A local shop did it for me, they did a lot to my car in the past and I was always more than pleased, but this time I´m still struggling to get them fix this for me, didn´t pay anything yet to them tho .. Wednesday (9.12) I´ll let my car check with smoke, to find the boost leak, also they will check if everything was installed properly (A/C is already empty, it wasn´t really tight under the air box). Another thing I noticed with stage 2, if I start the car in the morning and start driving, it howls pretty loud, coming from the turbos, I don´t have that with Stage 0. Either its a hard boost leak or on of the turbos is already trash |
| Bookmarks |
