BMW 3-Series (E90 E92) Forum
Misfire cyl #5 and oil around same spark plug
| 09-25-2020, 07:58 PM | #1 |
![]() 20
Rep 74
Hi all,
I have a 2009 E90 with N54. It’s got 100k miles. Recently, the vehicle started throwing out misfire codes around cyl #5. I replaced all the coils and spark plugs. The code appears under WOT only. At normal driving, there are no issues, but I get CEL on as soon as I floor it. So then I removed the spark plug #5 again and realized that plug was covered with oil. This time I replaced the whole valve cover gasket, replaced spark plug #5 also with the new one, and unfortunately the same problem. What is the next step now? |
| 09-26-2020, 05:37 PM | #2 | |
Rep 972
Does it rough or long cranks on cold start ups? I would let it sit overnight and then before you start it, pull that#5 plug and see if the tip looks wet. If so you could have a leaky injector. Do you know what index your injectors are? Ever done a walnut blast ?
Instagram : @Bimmer_bro
| 09-27-2020, 01:34 AM | #3 | ||
Rep 7
m
| 09-27-2020, 10:26 AM | #4 | |
![]() 20
Rep 74
I haven’t checked the spark plugs after I installed them. Injector removal tool will arrive tomorrow and I’ll swap injector 5 with a working one to see if it’s the issue. I assume all injectors are stock. I am not sure what index these injectors are. What am I looking there? |
| 09-27-2020, 10:33 AM | #5 | ||
Rep 972
| 09-27-2020, 10:57 AM | #6 |
Rep 16
Good advice but yes you can run mixed injectors. BMW states not to but there is plenty of examples of people doing it, and reporting its fine. My car has been running on mix of 12 and 9 on same bank for years! logs still look good. Log and review the data at start up and while driving.
| 09-27-2020, 10:59 AM | #7 | |
![]() 20
Rep 74
Last time I removed the coils I noticed lots of fuel around it and oil in the spark plugs. Replacing valve cover gasket should took care of the oil issue, I’ll check coils for fuel and plugs for oil again I have protool for coding so in case if I need to swap injectors |
| 09-27-2020, 01:46 PM | #9 | |
![]() 20
Rep 74
Does this mean at some point injectors were replaced? |
| 09-27-2020, 01:54 PM | #10 | ||
Rep 972
You could still have a bad injector tho. Best to determine first if #5 is leaking or not.
| 09-27-2020, 02:34 PM | #11 |
![]() 20
Rep 74
Make sense. What could be the reason for fuelly #5 coil? When I removed it the it was covered with fuel.
| 09-27-2020, 02:35 PM | #12 | |
Rep 972
| 09-27-2020, 02:37 PM | #13 |
![]() 20
Rep 74
| 09-27-2020, 02:44 PM | #14 | |
Rep 972
I would have some one run it and rev it a bit as your look to notice anything obvious( dripping or even a fine mist. ) Once you get the leak solved I would get a new coils for #5. Gas can ruin them pretty quick.
| 09-28-2020, 03:23 PM | #15 | |
![]() 20
Rep 74
I swapped the injector 5 with 1, coded using ProTool, replaced spark plug and Coil #5, still same problem. What I noticed though spark plug #5 was covered in clear liquid which smells like fuel. I installed the new plug and removed a few mins later without starting the engine and it was wet again. CEL comes on immediately I go over 2.5-3k RPM. (See the video below) All OBD monitors get ready with normal driving, no cell at all Last edited by HeatGun; 09-28-2020 at 03:39 PM.. |
| 09-28-2020, 04:48 PM | #16 | ||||
Rep 9
| 09-28-2020, 10:00 PM | #17 | |
![]() 20
Rep 74
I did not use a new injector, I removed injector #1 and swapped with #5. |
| 10-01-2020, 04:46 PM | #18 |
![]() 20
Rep 74
I bought a refurbished injector for cyl #5 and it’s still the same. Every time I insert the injector and remove immediately I see oil at the tip. See the image below.
https://ibb.co/tq83NjL I replaced the valve cover gasket 2 weeks ago due oil found in the spark plugs. |
| Bookmarks |
