The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > [E92] Seats from RHD to LHD
      03-11-2020, 07:25 PM   #1
Patryk7g
Drives: Fiat Stilo, e92
Hi everyone!
I bought full powered seats from RHD to my LHD e92
I add seat controlls with memory keys to left seat, so i have memory keys in both seats. I connect CAN to seats and they start working. But theres problem, memory was working until I add VO $459. Now memory is dead...
And next problem is seats think they are in wrong place in car, when i open left door i can move foward-backward right seat with upper swith. This same with seat heating buttons. I turn left, and right seat is heating.
Anybody can help me with this?
Thank You, and sorry for my bad english
      03-12-2020, 02:06 PM   #2
smallseafishie
Drives: AW 07 e92 335i + AW 11 X5 35d
2007 E92 335i  [0.00]
Just swap the electronic modules around between the passenger and driver seats. That'd be the easiest thing to do. You will need to get LHD specific seat buttons as that's different.
If your old seats were electric, swap those buttons / module over.
jaffles798.50
      03-12-2020, 06:03 PM   #3
Patryk7g
I tried this but nothing change :/
I bought LHD driver buttons. I have memory keys in left and right seats.
My old seats was only heated
      03-12-2020, 06:04 PM   #4
Diawal91
Drives: E90
+1
      03-12-2020, 06:40 PM   #5
Patryk7g
You mean this module?
I tried swap them beetwen seats, but without effect. Everything still work like before
      03-13-2020, 10:48 AM   #6
ptpending
ptpending's Avatar
895
Drives: e81
there is one pin in seat module connector which is shorted in harness when seat is driver and not shorted when seat is passenger
you have to examine your harness and you resolve problem
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      03-13-2020, 05:51 PM   #7
Patryk7g
Thanks for help, i will try this tommorow
      07-30-2020, 01:32 PM   #8
david51
david51's Avatar
France
574
Drives: bmw M3 F80
you have to reverse the electric motors because on the conductor you have 4 wires on each motor linked to 2 on the passenger
      04-18-2021, 02:58 PM   #9
Yellowdax
Yellowdax's Avatar
Greece
Drives: Bmw E92 320d
I want also to install M3 RHD seats in my E92 320d LHD. Finally is possible ?
      11-21-2021, 03:01 PM   #10
DenWorks
Turkey
Drives: 2010 E90 N47
i really could not finding that shorted pin in harness. I already disassembled the yellow connectors and all colored connectors whic are located behind the seat. Can you help me more please ?
[IMG][/IMG]
[IMG][/IMG]
      11-22-2021, 02:26 PM   #11
ptpending
ptpending's Avatar
895
Drives: e81
[IMG][/IMG]
[IMG][/IMG]
it is shorted on the seat part of harness, on before connector to seat module
you have to count wires
      04-13-2023, 09:13 PM   #12
ram00sa
Drives: 335i 09 e92 auto
any news, i am about to 2 RHD seats and install them into my LHD
any tips
      02-04-2026, 10:23 AM   #13
auraless
Poland
Drives: 2010 E92 320D
By trial and error, I have managed to find the shorted wire question
It's the brown wire on the black 8pin wire coming into pin2 from the seat harness. It's present only on one side of the wiring harness, so you need to remove it on the passenger seat plus add and ground it to driver's seat harness.
It also fixes the issue with seat moving backwards when you push the move forwards button on seat control switch. You don't need to swap wires/polarity on the motor.
Pictures attached (I already pulled it out halfway)
jaffles798.50
Tags
seats e92 rhd lhd coding
