BMW 3-Series (E90 E92) Forum
DME Code 2A2D LPFP... Please Help!
| 11-04-2018, 02:46 AM | #1 |
Rep 1
Drives: 2007 BMW 335i
Hello all!
I am new member of this forum and a long time viewer of e90 post. Recently, I have found myself in some troubleshooting issues and while I couldn't find it in the forum, I bet I'm not the first to have this issue and I'd love some input. Before doing any modifications to my stock 335i n54, I was getting these DME codes on the MDH stage 1 tune: 2AAF - Fuel Pump, plausibility 2A2D - Fuel low-pressure system. fuel pressure So I ordered and installed a Stage 2 Walbro 450 in-tank LPFP. After install, the car was running fine and I primed the pump for a couple days before doing pulls. BUT when I worked up to a third gear pull, the half engine light came on. This has been a consistent problem now for a few days now. Now my codes are: 2A2D - Fuel low-pressure system. fuel pressure 2A87 - Exhaust VANOS (which I know is probably an unrelated issue) 3100 - Boost-pressure control, deactivation Any suggestions on what to check next as far as the fuel pressure issue? Could it be that I need a new fuel pressure sensor? Has anyone else been here? I will take all the help I can get! ![]() Thanks in advance! |
| 07-16-2022, 07:16 AM | #2 | |
Rep 7
Curious what ended up being the issue on this?
| Bookmarks |
