Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Idles Terribly When Cold
      09-18-2017, 10:55 AM   #1
MooreBoost
Stand-up Philosopher
MooreBoost's Avatar
90
Drives: '10 E90 335i
For the past two weeks my '10 335i has idled terribly first thing in the morning when it's cold. It sounds like it's missing and shakes rather badly. As soon as I give it any amount of gas, it runs perfectly.
It idles perfectly when it's hot.
Thoughts?
Update in post 6. Resolved in post 12.
      09-18-2017, 11:01 AM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
Does it smell like fuel at start up?
First thing I'd do is pull the plugs and see if they are fouled with fuel or oil.
Fuel would be an indication of bad injectors, oil would likely be valve cover gasket.
If they are fine and the plugs are in good shape at the correct gap then I'd start to look elsewhere.
      09-18-2017, 11:27 AM   #3
335e92tx
ahat
335e92tx's Avatar
1126
Drives: Was '07-335e92 - Now '13-335IS
I had two probs that had almost the same EXACT symptoms. At 100K, began to get rough cold starts with raw fuel smell. Would clear up after 30secs. Replaced injectors and solved prob.
Within 2 months prob somewhat returned but slightly 'better'... not as consistent. Ended up being FP number 4. But it did throw high pressure fault codes I think..
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
      09-18-2017, 11:29 AM   #4
Funny you say that, I was going to remark on the HPFP being a possible culprit too but it's hard to diagnose without a code or datalogging capability.
      09-18-2017, 12:33 PM   #5
MooreBoost
MooreBoost's Avatar
90
I don't think I've ever smelled fuel, but will pay more attention.
I had the VCG done very recently.
90k on the clock.
      09-18-2017, 05:26 PM   #6
MooreBoost
MooreBoost's Avatar
90
Pulled the following codes-
Active Codes
29F2 - Fuel high-pressure system, fuel pressure
2B2C - Fuel high-pressure, plausibility, cold start
(Plus misfires)
Shadow Codes
2FCA
2FDA
2FDB
Is this further evidence of HPFP failure? Thanks.
335e92tx1126.00
      09-18-2017, 05:35 PM   #7
335e92tx
ahat
335e92tx's Avatar
1126
Active Codes
(Plus misfires)
Shadow Codes
2FCA
2FDA
2FDB
I think your there bud
http://www.bimmerfest.com/forums/sho...92&postcount=3
2FCA and 2FDA are also shadow codes that show up after any software code update and have to do with hpfp not priming correctly, but most people get those codes even on brand new pumps and they rarely cause any issues.
      09-19-2017, 07:17 AM   #8
MooreBoost
MooreBoost's Avatar
90
Taking the car to do the dealer on Thursday in hopes that it's the HPFP and that they cover it under the extended warranty.
Should I load my stock tune or keep the MHD on there?
Specifically, I don't want MHD on there for obvious reasons, but I also don't want to clear the codes so that the dealer is able to see them.
      09-19-2017, 07:40 AM   #9
335e92tx
ahat
335e92tx's Avatar
1126
Should I load my stock tune or keep the *** on there?
codes still should be present - ugh, but come to think of it, theres like a un-coded fault that will still be present too and that indicates and aftermarket tune. You might need to clear codes now and then pull MHD and then drive it for a couple of days.
g/l
      09-21-2017, 11:48 AM   #10
MooreBoost
MooreBoost's Avatar
90
Well, will the codes didn't come back before my appointment today, after reloading the stock tune.
The service rep mentioned the HPFP after I described the symptoms, and said they would warranty it if the codes came back. So that's good news.
Just have to wait now.
      09-21-2017, 12:22 PM   #11
335e92tx
ahat
335e92tx's Avatar
1126
good deal -
      11-07-2017, 02:32 PM   #12
MooreBoost
MooreBoost's Avatar
90
The car finally threw another fuel pressure code. I took it back in and they warrantied the HPFP. That seems to have resolved the issue.
      05-16-2022, 07:43 PM   #13
HB E90
HB E90's Avatar
61
Drives: 2010 E90 335i Space Gray
I know this is a very old thread but Its exactly what I had going on on my 2010 E90 335. I suspected the HPFP but after reading this I was convinced that was it. I scored a NIB OEM HPFP from another member here for $400 and did it myself. All good now. THANK YOU
2019 F150 S Crew 4x4 3.5 Twin Turbo - newest $$$ pit
2010 E90 SG 335i Sport, Premium, Nav. MHD, VRSF CP, 5" HD FMIC, DCI's, 1 step colder NGK's, Apex EC-7's and Michelin PS4S, Cree 6000k H8 LED Angel eyes SOLD
2011 Toyota Tacoma DC TRDOR 4x4 lifted and armored SOLD
2014 Acura MDX SHAWD wifes
      05-16-2022, 08:37 PM   #14
Saif2018
Drives: E90 335i
      05-24-2022, 10:59 PM   #15
Maxmil982
Drives: 2010 e60 535i xDrive
Stealer actually for the win
      05-29-2022, 02:37 AM   #16
Maxmil982
Leaking injectors maybe
