Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What's this noise?
      09-14-2016, 02:28 PM   #1
MrSilverwing
'07 E93 335i Sport
MrSilverwing's Avatar
Drives: Space Grey Space Ship
What's this noise?
Hey guys, I drive a 2007 E93 335i and I have a noise that's driving me crazy! I've looked at everything from air filters to wheel bearings to the rear deck lid to the rear seat latch. I hear this fluttering/squeaking noise coming from the driver's side rear wheel area only when driving between 0-40mph over moderate to bumpy roads, top up or top down.
Car rides on aftermarket 19"s with wheel spacers. Any ideas?
"Space Grey Space Ship"
JB4, BMS DCI, ALPINA Flash, Cobb CP, VRSF 3' Catless DPs, Magnaflow X-Pipe, PE-mod, 437M, PS4s, M3 Control Arms, M3 Paddles,
Follow Me on Instagram!
      09-14-2016, 09:33 PM   #2
MrSilverwing
'07 E93 335i Sport
Anyone?
      09-14-2016, 09:40 PM   #3
racermp
racermp's Avatar
Drives: F30 330i
Does it change when you slightly press brakes?
      09-14-2016, 11:25 PM   #4
MrSilverwing
'07 E93 335i Sport
Not really. I had the squeaky brake sensors a while back. This is different. Occurs during acceleration, coasting, and braking.
      09-14-2016, 11:29 PM   #5
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
wild guess: parking brake cable.whatever it is, good luck.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      09-15-2016, 10:21 AM   #6
MrSilverwing
'07 E93 335i Sport
I found one video on Youtube with symptoms similar to mine but with no further info in the comments. This noise has been bothering me for a few months and my mechanic couldn't replicate it, but I hear it every time I drive.
      09-16-2016, 11:22 AM   #7
MrSilverwing
'07 E93 335i Sport
I'm pretty sure I can rule out the following:
-Wheel bearings (since it's not a grinding noise as seen in videos.)
-Brake Sensors (noise is different, also it's from back left wheel, not back right where the sensor is)
It's more like something is lose/jiggling. I don't notice any mechanical difference while driving. Anyone have any ideas?
      09-16-2016, 12:06 PM   #8
djh2
Drives: '16 330e
2007 BMW 328i  [0.00]
I had a friend with an e46 convertible, she had a rattling sound like this. It ended up being a broken spring so the rattling sound was a loose part of the coil in the mount if I recall correctly.
It might be worth looking into mechanical components on the suspension, worn bushing etc.
      09-19-2016, 09:54 AM   #9
MrSilverwing
'07 E93 335i Sport
Thanks djh2!
I've been driving lately with no music and my windows all the way down so I try and spot the location and I definitely believe it's suspension related. It only comes from that corner of the car, and it happens with the top up or down, so I know it's not the convertible top. The sound isn't a squeak, it's a mechanical flutter, like bats in an attic.
So new potential causes are:
-Shock mount/bushing
-Shock
-Broken Spring
Anyone else want to chime in?
      09-19-2016, 12:11 PM   #10
X_Drive
X_Drive's Avatar
Japan
111
Drives: E46, E91, F20, F87, G87
2025 M2  [10.00]
2010 328i xDrive  [10.00]
Check your vacuum hoses from the Pressure converter to the exhaust flap. I have had a few cars that had damage to the hose(i.e. cracking, rodents, rocks) and make that awful noise. It's a free and easy check. It sounds crazy, but I went crazy isolating a noise like this and it was a leak in vacuum system in the exhaust flap circuit.
      09-19-2016, 01:40 PM   #11
MrSilverwing
'07 E93 335i Sport
I'll look into it! Crazy how many possibilities there are with this one noise. I honestly thought it was the wheel spacers but then I realized this has been occurring for longer than I've had them.
-Shock
-Broken Spring
-Vacuum Hose (Pressure Converter to Exhaust Flap)
      09-19-2016, 07:41 PM   #12
Laserdude
Laserdude's Avatar
Drives: 2007 Jet black e93 335
Off topic but I love your car I have an 07 e93 335 and I'm jealous of you lol
      09-20-2016, 12:49 PM   #13
MrSilverwing
'07 E93 335i Sport
Thanks Laserdude! I wanted a black one like yours and was originally disappointed that it was more than the SG one I eventually bought!
-Shock
-Broken Spring
-Sway Bar Bushing new theory that seems to fit the problem.
When I have time later this week or next week I'm going to take it to my shop with this laundry list of potential causes and tell them to get to work! I wish I had a lift in my garage so I could figure it out myself.
      06-04-2025, 02:59 PM   #14
Carlman3
Drives: 2020 X1, 2009 328i
Not sure if you ever worked this out, 9 years ago... But I have an e93, 2009 328i.
It makes this little chirping squeaking noise as you've described it's very high pitched. Sounds like metal to metal to me. It only makes the noise while driving over slightly bumpy roads. Well they're really smooth but the slightest undulations make this little chirp.
I made a recording, I can hear it because I'm listening for it, but I'm not sure how clear it will be to others... But here's the link:
https://recorder.google.com/3b008bb8...d-1b9e8c3f0b37
If anyone has any ideas I'm 'all ears'...
      06-04-2025, 04:09 PM   #15
oVeRdOsE.
oVeRdOsE.'s Avatar
4733
Drives: F25 E91N54 Audi Avnt Cayenne
on my case it was the rotor dust shield. The rust around the bolt made it loose and it was grinding in the inner rotor.
Got some stainless washer and it was fixed.
