Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Removing upper radiator hose. Any tricks?
      08-20-2016, 12:56 PM   #1
wren57
Roll Tide
wren57's Avatar
661
Drives: 335i
Broke the nipple off the upper rad hose on the drivers side, going to replace that entire hose but I can't get it off either end even after pulling the C clips out. I'm wiggling each end with so much force the car is moving on the jack stands, and I don't want to break the larger nipple on the radiator. Any ideas?
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
      08-20-2016, 02:56 PM   #2
Unknown_Car
Unknown_Car's Avatar
Drives: Few and diffrent
Keep wiggling i had to do that for a while thill it came loose.
      08-20-2016, 03:12 PM   #3
PN3UMA
PN3UMA's Avatar
Drives: 2015 M235i
I just replaced mine last week. Just pull hard. I mean real hard, and wiggle it.
      08-20-2016, 04:08 PM   #4
Built My Way
Built My Way's Avatar
Drives: ...when not replacing gaskets
The connector is keyed and pulls straight out. It takes a bit of doing but be patient and just keep rocking/wiggling until the seal breaks. No need to exert yourself (too much).
      08-20-2016, 08:08 PM   #5
wren57
Roll Tide
wren57's Avatar
661
Drives: 335i
Spraying silicone lubricant in the c-clip channel did the trick.
      08-21-2016, 06:34 AM   #6
Built My Way
Glad to hear you got it off. Be careful not to get any silicone on the o-ring.
      08-21-2016, 08:18 AM   #7
Efthreeoh
Glad you got it off. My hoses were stuck on so bad (after 230K) I had to remove the radiator, tie it down to my work bench and use two large screw drivers to pull the hose connection apart. I think the stupid BMW coolant hose connectors are the epitome of BMW over-engineering; I've yet figured out the purpose of them over a simple hose bib and worm-screw clamp.
Just wanted to rant a bit
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
      08-21-2016, 02:07 PM   #8
1QuikWS6
No 55mph
1QuikWS6's Avatar
1671
Drives: F32 435ix MSport
After replacing every hose as regular maintenance I have found that the BMW clip n' o-ring is great for installing the hoses, especially since many would be hard to get to if using worn clamps - but not so great for removing
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      08-21-2016, 02:15 PM   #9
Efthreeoh
I did all mine too (wrote a DIY) and I think they are the most useless apparatus ever devised to solve a problem that didn't exist. I think that even for installation (on anything but a factory-fresh system - i.e. on the assembly line) reconnecting can leave doubts as to the validity of the connection. I know of two BMWs where the connection popped off weeks after installation.
I'll go hose bib/worm clamp any day of the week. It's the Forrest my friend...
      08-03-2019, 02:09 PM   #10
kevin305
Drives: '06 330i 6M, '14 435i cabrio
After jerking, pulling, wiggling for 15 minutes I realized the following: fitting slides easily until the back egde of the wire clip channel on the hose catches on the front edge of the groove on the radiator fitting. Since I was replacing the hose anyway, I just stuck a small screwdriver in the hose fitting and snapped the back edge off. Problem solved - the hose slid right off. If you're re-using the hose try gently prying under the back edge to lift it up over the front lip of the retaining channel.
      08-03-2019, 02:18 PM   #11
dpaul
Drives: 2009 E90 335xi, 2011 E93 M3
Carefully placed small pry bar works for me. Not magic.
But I agree with Efthreeoh. Overengineered to answer a question that wasn't asked.
      08-03-2019, 02:43 PM   #12
e90yyc
Art Collector
e90yyc's Avatar
2875
I’m surprised more people haven’t used heat. Unless they have and are still having no success.
When I first ran into this issue, I got out my heat gun, and the fittings came off without too much effort.
PhaseP1070.50
      08-04-2019, 07:02 AM   #13
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
I'm guessing they speed up the installation time on assembly line and good for parts business
      09-22-2022, 06:37 PM   #14
Nathan328i
Drives: 2008 328i
The upper rad hose on my car was welded on and I knew if I kept yanking any harder (that's what she said) I would break the radiator neck. Had to use a dremel to cut out a large piece. Even then, I had to carefully wiggle it for several minutes before it broke loose. What a nightmare.
      09-22-2022, 07:39 PM   #15
e90yyc
Art Collector
e90yyc's Avatar
2875
I’d say you yanked a little too hard. You should probably see a doctor.
      09-23-2022, 05:18 PM   #16
Pittz1
2018 M3 ZCP / 06 330xi
217
Drives: 330xi 2006 / 18 M3 ZCP
I poured hot water from the sink on the ends... came right off. This was after fighting it for 30minutes.
      09-23-2022, 08:25 PM   #17
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2007 BMW 328i E91  [10.00]
2009 BMW 328i E91  [7.56]
2006 BMW 330i  [8.17]
2007 BMW 328i  [8.83]
2013 BMW X5 35i  [8.43]
2011 BMW 528i  [9.07]
I just went ahead and destroyed the radiator, isn't that the proper way to do it???
      06-19-2023, 01:35 PM   #18
XCT
XCT's Avatar
Romania
10
Drives: E90 318i M pack
for all big hoses the way it worked for me is to insert a flat screwdriver and twist it in those small walls with one hand and the other hand grab and wiggle the hose with all 4 fingers while pushing on the mount with the thumb, dont just pull like a money as u risk breaking it
      03-18-2024, 11:21 AM   #19
Jay Morac
Jaymorac11727
Drives: BMW 328xi 2007
Shouts out to this forum saving me from braking s* 😂 appreciate all of you
      04-04-2026, 06:59 PM   #20
hav
Drives: BMW M550i
Apologies for bumping an old thread but I wanted to thank e90yyc and Pittz1 who both recommended using heat. After half an hour of wiggling, jerking, twisting, pulling and getting nowhere, I found this post.
I hit it with my heatgun on medium for no more than a minute and wiggled it right off in 10 seconds or less. It didn't take a ton of heat, even a hair dryer would do the trick. Thanks again guys!
