Jacob.falkmfg
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Comfort Access Retrofit Project
      01-03-2016, 12:33 PM   #1
ramez75
ramez75's Avatar
Drives: 2015 640i xDrive GC (F06)
Hey,
I have did some reading but there is nothing substantial on this topic other than its a very expensive retrofit. I want to attempt to do it as I am keeping my BMW for a long time and always wanted this feature.
I have a 2009 BMW 335i xDrive Coupe.
I will post with my progress on this, cost and pictures as I get to the install phase. I know that programming will be required which not my strong suite so will need to find someone to do this part. I have the cable, NCSExpert and Edibias all functional as was used to do simple programming and programming of the Front and Rear PDC.
I got this so far:
- Control unit passive go (61359134708) (x1) - $60
- New Truck antenna bracket - $3
- Used BMW Left FRONT DOOR HANDLE COMFORT ACCESS - (51217207565) - $40
- Used BMW Right FRONT DOOR HANDLE COMFORT ACCESS - (51217207564) - $80 (need painting)
- Bumper antenna (x1) and Interior Antennas (x3) - (61356922212 & 61356922211) - $55
- Driver and Passenger wiring door harnesses with comfort access - $50
- Comfort Access wiring harness, i couldnt find one on ebay, so this was made for me by Dumitru (he is a member on the forum). So if u can't find one or make it, he definitely can make it for u and the price is reasonable.
Also I found the below link, I will use this to figure out the antennas location.
http://workshop-manuals.com/bmw/3_se...rt_access_sys/
Check below for part numbers
http://www.realoem.com/bmw/enUS/show...diagId=41_1971
http://www.realoem.com/bmw/enUS/show...diagId=61_1718
So below is an update of what I have done. Progress is slow as it is my daily driver.
I have removed the back seats and rear console to install the rear CA antenna. I also removed the trunk liners to install the CA passive GO module (goes in the PDC device holder) and the luggage CA antenna.
After you remove the liners from the trunk you have to also move aside the insulation to access the PDC device holder. There are 3 screws holding it so unscrew them and then try to wiggle it out. Once out but the CA Passive GO module and then reverse the instructions on how you got it out.
Removed the center console trim. It's straight forward and there is a lot of DIY instructions and YouTube movies. Below are few pictures.
Below pictures connecting CA wiring harness to the PDC module plug.
Below are pictures showing the connection of the CA wiring harness to fuse 61 in the JBE fuse box. For my car it is pin# 10. I took the glove box out. There is alot of DIY out there to describe how.....and then you have to remove the 4 torx screws to be able to get back to the plug behind the JBE fuse box.
Below are pictures showing connecting the CA wiring harness to the passenger wiring harness. Same applies for the driver side. For my car it is as follows white wire to pin# 12 and red wire to pin# 25. Use an 8mm socket with a small rachet to loosen the screw holding the plug from the door to the car. There is a black thing that you will need to pull it out to disengage the plug from the wiring harness of the door. Once unplugged make sure to take off the blue thing before attempting to put in the pins into the plug.
Below is connecting the CA harness to the CAS module. Ofcourse take the 3 screws off to remove the under tray under the steering wheel. Disconnect the various connectors and get it out of your way. Unplug the CAS connector. Connect the wire from the CA harness to pin# 30 on the CAS connector. I used a quick connect.
Passenge door wiring harness and the CA handle install. Be careful not to break any of the plugs.
Programming was done by Dumitru. VO $322 adding comfort access.
After I purchased the CA key (Dumitru got me the key and ofcourse the option was added to my Car VIN as seen below). I used www.bmwvin.com to confirm
I got the key. I put it in the slot and turned the car on to make sure the car recognized the key. Once this was completed I turned the car off the key out. I turned the car on without the key in the slot and BINGO the car turned on
Project was success. Below is a clip to show the CA retrofit in action.
Let me know if any one have any questions. Hope this helps
15 F06 640i xDrive Gran Coupe/Grey
Appreciate 19
      01-03-2016, 01:27 PM   #2
noah.s
Drives: 2011 335i M-Sport
I don't have anything to add other than that you'll need the comfort access fob. I know they aren't cheap to get programmed and everything.
Also, try to look on Craigslist to see if any cars near you are being parted out. You might get lucky and they'll have CA.
      01-03-2016, 01:42 PM   #3
Black09BMW
Black09BMW's Avatar
39
Drives: 2009 328i xDrive
Good luck! I've only heard of maybe one other person that has done it successfully but didn't hear much about it.
      01-03-2016, 01:45 PM   #4
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3924
Drives: (Sold) 2011 E92 335i ZMP 6MT
In
      01-03-2016, 01:52 PM   #5
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Not trying to down you on this retrofit OP but I think the main snag to why you do not see many people jumping to do this retrofit, is just the process of getting a new key to work with your car. BMW does not authorize this not even to it's dealers as far as I've read. (Unless you gotta few links in higher places that we don't about and would kindly like to share) This post marks me as subscriber so I'm in as well.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
Afanz19.00
      01-03-2016, 02:10 PM   #6
dannyjones
Drives: 2011 BMW 335i M-Sport
I'm following too. Good luck
      01-03-2016, 03:32 PM   #7
Nitrousbird
Drives: '07 E92 335i 6MT
Though I already have Comfort Access (a must have option IMO), I'm still interested in seeing the final results of this project. I have a feeling it will be cost prohibitive when all is done.
This is why you don't see a lot of adaptive cruise retrofit projects due to the insane cost (both now and when ordered new). Im a cruise junky but it's too much to swallow for a retrofit project (and I never saw a single used car being sold when I was shopping with this option).
      01-04-2016, 10:28 AM   #8
ramez75
ramez75's Avatar
Does anyone know if painting the door handles will impact the functionality of it. I found a used door handles with the carriers for both driver and passenger sides for $220 but not to my color match and I was wondering if I can paint them and will they still work.
Any input on that is greatly appreciated
Thanks
RB
      01-04-2016, 11:06 AM   #9
noah.s
Thanks
RB
I don't think painting them will affect anything. I know you can vinyl wrap them and not affect comfort access.
      01-04-2016, 11:09 AM   #10
ramez75
ramez75's Avatar
Thanks Noah
      01-04-2016, 12:03 PM   #11
ramez75
ramez75's Avatar
Hi,
Please can you tell me if your driver handle has a keyhole. You mention that you have Comfort Access. The handles I am seeing do not have key hole and want to make sure I am getting the right one
Thanks
RB
      01-04-2016, 12:18 PM   #12
NOITALL
Drives: 4 wheels
Hi,
Thanks
RB
Only driver's door has the key hole.
If you're seeing a driver's door handle for sale without a key hole, how are you supposed to get in the car?
Make sure you're not mistaking the other handles with the driver's.
      01-04-2016, 01:42 PM   #13
patents
Drives: 2008 328i
^^^ This. How are you going to get the key itself coded? Dealer codes keys by VIN (and you have to verify ownership), and your VIN is for non-CA. Even if the dealer bends the rules and agrees to make a key (I don't think they code them anyway, they are coded by BMW NA and shipped to the dealer), how are they supposed to know how to code it?
If you ask me this makes the project almost a nonstarter. Two things come to mind: find a wrecked donor car with CA, buy it, take title to BMW and get key made, then swap all the electronics to your car (so your car thinks it's the other car). Have fun taking it in for service, when they scan the car it will come up with the wrong VIN. Or find an aftermarket system that would work. They probably interface like a remote start system, and we know that is very difficult to achieve in our cars.
Or just trade your car for one with CA.
      01-04-2016, 01:58 PM   #14
DJtoad
Drives: 2010 535i M Sport
Wow, that's a pretty ambitious project! I don't recall anyone successfully completing a CA retrofit. I would expect a considerable amount of coding and maybe even harness replacements. Good luck and please keep us posted!
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus
      01-04-2016, 03:51 PM   #15
fazman
Drives: 335 e90
Hey,
I am in the process to purchase:
- Control unit passive go (x1) - $60
- Bumper antenna with the bracket (x1) - $15
- Interior antenna (x3) - $60
Currently I am looking for the driver and passenger handles as they are different when you have CA322. I don't know though if I need just the handle or the whole thing (cover, carrier, etc.).
Also looking for the wiring harness that I need for the control unit passive and the antennas
IF any one has information on this or have these parts for sale it will be greatly appreciated
Thanks
RB
I want info on how to retrofit Front and Rear PDC + Coding on to a pre-lci car with no PDC.
      01-04-2016, 05:05 PM   #16
ramez75
ramez75's Avatar
[QUOTE=fazman;19159594]I want info on how to retrofit Front and Rear PDC + Coding on to a pre-lci car with no PDC.[/Q]
This is what I did
http://www.e90post.com/forums/showthread.php?t=700864
      01-04-2016, 05:40 PM   #17
Nitrousbird
Hi,
Thanks
RB
Drivers side and trunk have a keyhole. Passenger side doesn't.
      01-04-2016, 05:59 PM   #18
ramez75
ramez75's Avatar
So according to the below link
I don't need the carrier all I need is the below
- 51217162439
- 51217162434
- 51217207564
- 51217207565
      01-05-2016, 12:44 AM   #19
Manberg
Manberg's Avatar
Drives: 2011 e90 335i
Interested to see how this works out, the only factory option I wish I had.
M-Sport, 6MT, PPK, JB4 ISO + Rev.3, VRSF 7'' FMIC, VRSF Catless DP, BMS Charge Pipe, MFactory LSD, Öhlins R&T, M3 Control Arms, Rogue 6MT Bushings, Remus Exhaust, Duke Dynamics CF Diffuser, Cyba Scoops, VMR VB3 19s, BMS Clucth Stop
      01-05-2016, 02:09 AM   #20
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
- 51217162439
- 51217162434
- 51217207564
- 51217207565
You don't need the first two. It's the same with or without CA. The difference is with or without light package (all north american cars have the light package).
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      01-05-2016, 05:13 AM   #21
ramez75
ramez75's Avatar
Thanks you are right. Looking at it again its the same number for light and comfort and light alone
      01-05-2016, 08:10 AM   #22
lichtgelb
Drives: 2009 E93 335i
My F10 has adaptive cruise with stop and go. I might not have checked this expensive option if I bought it new but damn if it isn't the shiznit. On my first real road test I drove between Wichita and KC without ever hitting the brake or gas pedal. While everyone else is jockeying for position on the road you just set the following distance and speed and let everyone else knock themselves out passing each other. Come up on a slow right laner with three faster cars on your left blind spot? No worries, just let the cruise follow until the left lane is clear to pass.
But you want real luxury opt for comfort close doors. I used to close the door myself but my F10 shuts them for me lol.
