The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > VRSF 7" intercooler install
      08-11-2015, 08:50 PM   #1
08n54335i
Drives: 2008 335i
I am posting this because of misleading posts about this product related to install.
First: the 15 minute uninstall is the worst part. The factory clamps need to be cut off with a dremel like tool or carefully pryed with a screw driver at the joint.
Look at what your cutting to fit the 7" VRSF intercooler...Forget about trimming to leave 1/4" material that does nothing - cut it all out. VRSF fits like a dream and goes in easier than that I've read on this forum. I used an angle grinder to cut the base off and tin snips to cut the top. Then pulled the top remnants off with some twist action and pliers.
Installation can be done with air tools easily with wobble extensions. There is plenty of room to get a 10mm deep socket on all clamps. If you don't have air tools you can use a regular 3/8 or 1/4 drive ratchet with cheap wobble extensions.
I was intimidated after reading about others install times and tools needed. If you're an experienced tinkerer this install will be a walk in the park.
      08-11-2015, 10:57 PM   #2
Tsujen
Tsujen's Avatar
90
Drives: 2007 BMW 335i
Air tools makes everything easier my install wasn't so bad, definitely can make it faster a second time if needed.
07' 335i Monaco Blue - Cobb V3 / vrsf 7" fmic / vrsf cp / bms dci
      08-12-2015, 03:27 AM   #3
rif75
France
77
Drives: BMW M4 LCI ZCP and BMW M5 f10
But just to confirm since I have received mine today, with the M bumper, you have to remove the bumper for sure or no need?
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
      08-12-2015, 07:43 AM   #4
BadDogmotorsports
BadDogmotorsports's Avatar
Drives: 335i
Great points. People tend to make it sound a lot more difficult than it really is.
      08-12-2015, 08:53 AM   #5
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
Unless these intercoolers install themselves, it's always hard to install (That goes for any intercooler).
      08-12-2015, 10:45 AM   #6
Bimmer 808
MT or bust!
Drives: 2010 E90 335i M Sport, 6MT
2020 X3 M40i  [0.00]
2015 M235i  [0.00]
2006 330i  [0.00]
2010 335i  [0.00]
i have the m bumper and kept it on. did the install on a lift.
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
      08-12-2015, 12:56 PM   #7
frenchie1013
frenchie1013's Avatar
90
Drives: sedan
Installed my vrsf 7" in a few hours just taking my time
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets
2014 X5 50i
BMS stage 1, Dinan intake, F85 Knee Bolsters
      08-12-2015, 05:55 PM   #8
SeanS54
SeanS54's Avatar
210
Drives: E92 M3, E46 M3, F82 M4, Tacoma
I left my bumper on when I installed mine. I did the install in my garage using floor jacks.
http://www.e90post.com/forums/showthread.php?t=821224
      08-13-2015, 12:00 AM   #9
Jeef
Drives: AW E92 335i
I like to remove front bumper so you can just cut away and not worry about cutting the bumper
      08-13-2015, 02:43 AM   #10
rif75
France
77
I don't have a lift so no choice I think for me
      08-13-2015, 04:32 PM   #11
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
I'm glad you guys are enjoying your intercoolers
      08-13-2015, 05:10 PM   #12
rif75
France
77
Can someone tell me exactly witch part I have to cut for the install on e92 with M bumper? I want to do it without a lift so no other choice that to remove the bumper?
      08-14-2015, 05:40 AM   #13
rif75
France
77
Can you tell me if the process is the same for the VRSF with an e92 with M bumper
      08-14-2015, 06:47 AM   #14
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
It sure is. You aren't modifying the bumper, just the black plastic shroud.
      08-14-2015, 04:16 PM   #15
rif75
France
77
Okey, perfect then I'll try with a lift without removing the bumper...
      08-14-2015, 06:41 PM   #16
Some Asian Guy
Some Asian Guy's Avatar
Drives: 2015 BMW X5
I installed mine a couple weeks ago in my garage with hand tools. I removed the front bumper, because it's only an extra five minutes, and it makes cutting the shroud easier. The most challenging part for me was connecting the lower chargepipe on the driver side. The rest of the install was pretty easy.
      10-07-2020, 10:48 PM   #17
kurtsmithe92n54nz
Drives: e92 335i
How is everyone mounting them ? I want to solid Mount it to the chassis for when the motor moves (solid mounts) for track day , cheers
      10-08-2020, 09:23 AM   #18
1Bad335turbopsi
1Bad335turbopsi's Avatar
Drives: e90,e92,e46 zhp,68 442
If you want to mount it solid you are going to have to make some solid mount's for it.
The usual mods....
      10-08-2020, 12:56 PM   #19
relative4
Drives: '08 335xi E90 MT stage 1+
Man, that is so meta.
