      01-22-2019, 06:40 PM   #463
trad50i
Drives: 2011 X5 50i
2011 X5 50i
Originally Posted by roman705 View Post
Hi everyone! New to the forum. I have an 2009 X6 with 60k miles and had all the same issues everyone else was having. Burn a quart of oil once a week and white smoking coming out the pipes when idling. Took the car in as soon as the lawsuit was approved in October. They tested it ONLY once and said I would be getting a new engine. Was told the engines were on backorder till January. Called them end of December to just get an update and they said the lawsuit has changed and I needed to bring my car back in again to get tested. Now BMW will only cover things related to OIL CONSUMPTION. Nothing else. So instead of getting a new engine (which they now say is still backorder for 90days) I got all new valves instead. Didn't even get a choice. They said "BMW will fix your engine to what ever is cheapest for them to do so to fix the oil consumption problem." Hence, no new engine. But it was ALL FREE and I got a loaner for 2 weeks. They told me my turbos were ok, but the turbo lines needed to be changed. Would cost about 3k but they offered me 10% off. Can't afford to do that. F'n BS. Love the car. Hate the problems. I just put it up for sale. Hope everyone else is having better luck!!!
I guess i'll take my 2011 50i with 113000 miles in to get the oil testing done. i think i'm burning a quart every 300-500. They'll hit me with the turbo hose crap too. It does run ok and only smokes sometimes . Thanks for the info
      01-22-2019, 09:59 PM   #464
dennik
Drives: 2015 xdrive50i
On my car the dealer replaced valve stem seals, rear main seal, rear coolant cover (the one above the rear main seal, updated versions), and bunch of bolts and gaskets as part of the settlement. They provided a rental for me.
I also replaced the oil return cover myself in November, and while in there replaced the turbos ( one has exhaust leak on that seal for westgate flap, and both of them were leaking oil on intake side), oil return lines, that coolant Y pipe, crank case vent pipes (were cracked, caused oil smell when heat on) and all gaskets and seals as per TIS. So the parts were $650 from ecs tuning, the vent pipes about $100 from the dealer, and turbos $625 each from the dealer. 2k in parts but saved some money on labor.
      02-09-2019, 06:02 PM   #465
elmasry17
Drives: 2011 BMW x5 50!
I was qualified for engine replacement since i failed oil consumption test multiple times on Oct 3, 2018 so the dealer said they will replace the engine for me but i have to contribute 30% of the cost but my SA said they will give me a bigger discount since im a loyal customer with them. So i agreed and they kept the car since Oct 3 and they gave me a loaner till they replace the engine. My SA emailed me yesterday Feb 8 2019 and said my engine just arrived and they will start working on my car on Monday Feb 11 2019 and that it will take a week to finish the job. So ill keep you guys posted and ill upload the service paper work to show everyone what exactly was done and what other associated parts was replaced. My SA told me that i will have my turbos replaced as well which i have some doubt. Does anyone know when engine is replaced they have to replace new turbos? Was that part of Bang class action lawsuit settlement agreement? Anyways ill keep you guys in the loop once i get my car back.
      02-09-2019, 06:42 PM   #466
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
No, turbos weren’t part of Bang vs Bmw. Congratulations btw, hope the replacement goes smoothly.
      02-09-2019, 10:43 PM   #467
elmasry17
Thanks brotha! Thats so weird that my SA confirmed by email that both turbos will be replaced as part of engine replacement package. I guess i will have to wait till monday and give my SA a call to confirm about replacing turbos.
      02-12-2019, 11:19 AM   #468
CT77
Drives: 13 X5 50i - 13 Hybrid 3
I didn’t submit my claim on time but I have a great reason for not doing it: I was in Afghanistan for the month of October. I know service members have a lot of protections for things like this I assume I should contact the firm in charge of this Class Action. If that doesn’t work I guess I’ll stop by the JAG office and see how they can help. Anybody have any suggestions?
      03-09-2019, 07:59 PM   #469
MYN63X5
Drives: 2011 BMW X5 xDrive50i
Post Thank You Thank You Thank You!
Hey Everyone, been browsing the forum for a while, but just registered as a member today. I did so because of this posting right here. I just purchased a 2011 BMW X5 xDrive50i and have had a few bumps in the road since I got her. One month into it, it wouldn't start for like 30 mins and when it did every dash alarm possible was on. Turned out to be Low Pressure Fuel pump. And if it wasn't me being pissed off and making it an issue with the stealership I would have had to pay for it, but I didn't. All was well all about a month ago. It went into Limp mode and threw codes showing cylinders 5 and 6 misfiring. Changed out the Spark plugs and the Coil Packs for the affected cylinders but did not fix the issue. So the only thing I can think of, and the suggestion of the stealership service advisor was the fuel injectors. Upon which they quoted me close to $3k for the repair!! Then today I saw this post about the BMW Service Bulletin (B001314) that speaks directly to this issue and that it should be covered. I called BMW and all they tell me is there are no Active Recalls for my vehicle. But did admit that there could be Serve Bulletins out there for my X5 but they couldn't confirm that unless I bring the X5 into them.
So Monday I will bring her into them and let them do what they need to do to verify the service bulletin, and I will ask if there are any others that would apply and to have that work too. SOOOO THANK YOU FOR THIS POSTING!!! I hope it makes the difference between breaking the bank and getting it fixed for free.
Anyone know of any other Service Bulletins that may apply to my X5?
      03-09-2019, 08:18 PM   #470
MYN63X5
Hey elmasry17, I'm about to put my X5 in the shop for misfiring cylnders 5 and 6 which I believe is the Fuel injectors. I'm hoping it is covered under the service bulletin B001314. Aside from that I have noticed that it also goes through oil more than my 2000 3-series and 2005 X5, but doesn't smoke. How did you ask for the Oil Consumption test, and if it fails does that mean it automatically qualifies for a new engine?
      04-10-2019, 08:47 PM   #471
LittleAbner
Dinan S2 X5 50i
Drives: X5 50i
2013 X5 50i CPO w/ Dinan S2 installed by the dealer. I am not sure how I fair with this one. However, my engine seized last month, and the service advisor said BMW USA approved an engine replacement at my $50 deductible and provided me a new vehicle to use. I have had the X5 for about two years now, purchased at 35k, seized at 70k. In those two years, the X5 was in an out due to various oils leak related issues surrounding the main seal and turbos. I was told by the service advisor that he does not know when a new engine will be in, and I also do not have specifics on the parts. He mentioned people waiting "months."
Personally, I would like to have them purchase it back or offer a hefty discount on the purchase of something else. Either way, when I hear anything, I will let you know how this one plays out.
      04-18-2019, 12:01 PM   #472
Splinter X5
Drives: 2013 x5 50i. Msport Mperf
Mine was approved this week for valve stem seal repairs. $0 out of pocket. 63k miles and I was burning 1 qt about every 500 miles. I asked my SA why mine was approved for "repair" while it seems everyone else with similar miles is getting a full replacement. He can't answer the question and says it's up to BMW NA. Anyone have any insight here. Do I / should I be pushing back on this? Thanks in advance for any advice or lessons learned.
2013 X5 Msport, Mperf
1970 BMW 2002
1962 Ford Unibody Frame Swap on 2011 CVPI
      04-18-2019, 05:17 PM   #473
chadism
Drives: 2016 X6M
2011 X5 50i M Sport 68K miles
I have owned this vehicle for 6 years, bought it as a lease return w/ 32K miles. It has always burned oil and I have had it in and out of the dealer wherein they replaced turbos, entire fuel system, pretty much everything over the course of ownership. It started smoking badly last summer. Fast forward to today...it has been in the shop for almost a month. I turned it in as a class action suit candidate and was told they would perform an oil consumption test. The following day the dealer called and said it would need no test and that BMW NA had approved an engine replacement and that I would be responsible for 15% of engine cost or $1250. I accepted and requested a loaner car, which the dealer denied but offered a rental car with a maximum dealer cost value @ $44/day, which I accepted. It is worth noting that when I dropped my vehicle off at the dealership I had already emailed the settlement claims administrator and then was called by BMW NA after the dealer initially said that I would have to pay for the oil consumption test. I will continue to post as events unfold. Am quite excited and feel vindicated to receive a new engine after years of knowing the N63 was defective. Since I am just out of warranty, I am stacking parts to perform the upgrades I have wanted to do for a while. Your posts and advice will be appreciated as I am looking to do wheels/tires (I like Greddy's but it looks as if TSW no longer makes the 22" version of the Interlagos), suspension, catless downpipes, new headlights, exhaust, tune, and an AVINUSA headunit. My vehicle does have the active suspension so I will need a bit of help there. This is particularly funny in that I literally work across the street from KW suspension manufacturing headquarters and nobody there can give me a straight answer on what components I need and who can install them for me.
      04-24-2019, 10:37 AM   #474
heatmizr
Drives: E70 X5 50i M-Sport
Keep these updates coming, very much appreciate all the info being accumulated here.
Splinter - if it were me, I would be happy with just getting that repair done for zero cost. A replacement might take many months to secure, but that repair could be much quicker.
I have zero issues at 58k at the moment, unless you call burning a qt of oil every 850-900 miles an issue...
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      04-25-2019, 03:00 PM   #475
witz323
Drives: 2020 M8 Comp
2011 X5 50i
Currently has 121,000 miles. Has been burning oil significantly since I purchased the car as a cpo 5 years ago. Typically add a quart every 500 miles.
Was in for service at dealer last month at 119,900 miles and they offered me a new motor for $7,500. I chose not to buy the engine. I probably would have for $3,000. The car has been very reliable for me the last 5 years. I've put on over 70,000 miles. I don't like the oil mess on the back of my alpine weiss x5, nor do I care for the constant smoke out of the tailpipes. Adding oil is kind of annoying, but overall it's been pretty good. I plan on driving it until it gives up.
2014 Cayenne GTS
2009 C4S Cab
2004 Dodge Viper
2020 M8comp
      04-26-2019, 09:04 AM   #476
X5 MAN
Drives: 2011X5 50iM-Sport;2016X3 35i M
Originally Posted by witz323 View Post
2011 X5 50i
A quart every 500 miles . So if you reached 8 quarts of oil after 4000 miles, you would have had a free oil change.
I don't bother about oil consumption either. Its a blessing in disguise. Oil remains fresh.
Will worry about CAT when it gives up ., then I will sell it off.
      04-26-2019, 12:18 PM   #477
Sophisticated Redneck
Drives: 2012 BMW X5 50i
2011 X5 50i
Mine was a bit worse, about a Quart every 350-400 miles (have 144,000) and huge plume of smoke at every stop light, but with catch-cans and adjusting the crank-case pressure to a negative 8 psi made all the difference, now only burn a pint every 1200-1500 miles (depending how hard I drive it) and no more smoke out the pipe at stops. Its not a bad job to do but is time consuming and will kill an entire day to set it up and about 300 dollars in parts to do it right. Well worth it though. You will also notice a nice boost in throttle response and power off the line.
      04-26-2019, 12:38 PM   #478
9vapors
Drives: CB X5M
Still waiting for you to write up something for the S63... I think there is a reason they don't make a kit already... the S63 is an odd one.
      04-26-2019, 03:19 PM   #479
Ya I need to inspect the CCV tubes so I can understand all the check valve placement for the S63, they didnt have any in stock at the dealer when I was there, I will be there again tomorrow, hopefully they have some now.
9vapors663.50
      05-02-2019, 10:35 AM   #480
witz323
Wow, good for you. How long have you had that set up for? I would be inclined to do something like this as I would prefer to keep pounding miles (hopefully another 20-40k) on this ride. I am not mechanically inclined at all, so I would have to pay my shop to do this. If I could do it for under a grand i'd be inclined to try it...providing you have some proven miles under your belt.
2014 Cayenne GTS
2009 C4S Cab
2004 Dodge Viper
2020 M8comp
      05-02-2019, 12:10 PM   #481
I've been running catch-cans for over 40,000 miles now, the current setup has just over 20 thousand miles on them. Makes a Incredible difference on the n63. No issues as long as you clean the bronze micro filters every oil change or 5K miles which is easy to do. Total cost in parts is about 300, labor should be no more then another 300-400
      05-15-2019, 12:16 AM   #482
s390er
Drives: 2012 BMW X5M
everyone facing s63 issues similar to the n63 , post your concerns on the us and Canadian safety sites , checkout this thread and follow up !
https://www.xbimmers.com/forums/show....php?t=1611893
      05-16-2019, 02:57 PM   #483
heatmizr
I wanted to bring this up again and see what's what...
Much earlier in this thread several ppl reviewed their Bang lawsuit papers and some said they read instructions saying that they had to "apply" before a certain date to be part of the lawsuit.
I swear I read mine three times and it stated flat out, that "by doing nothing, you will be included in the lawsuit." I saw a couple other options like if you wanted to sue BMW on your own, you had to opt out, etc.
I just wondered if anyone above who has initiated the lawsuit replacement process could chime in on how they did so. Did you just drive into the dealership with your papers? Or did you "apply" somehow first?
heatmizr [Todd]
e90 328i - sold
      05-17-2019, 09:12 AM   #484
dmack92
Drives: 2013 xdrive50i
Not sure if this helps or not, but I didn't do anything with any papers. Drove into my dealer and talked with my SA about oil consumption and smoke coming out of the tail pipes. They took it all from there and told me about different scenarios and the outcomes based on potential findings and put me in a loaner.
